km 4030/4035 developing unit (refurbishing it)
  • chexin51
    • Aug 2008
    • 37
    #16
    cleaning toner lines off mag roller
    I have successfully cleaned 5 or 6 units
    Rule #1
    Solvents are NOT needed to clean the dev unit
    1. open up dev unit - 2 gold colored screws
    2. vacumm out all toner - toner clumping can cause copy quality problems
    note: it is highly recommended that you make sure the toner being used
    is original toner from Kyocera - some compatible toners are prone to pale copies and other problems so be forewarned
    4. you can remove the metal doctor blade - 2 black screws
    5. vacumm this blade and then wipe the black magnet on the underside with a Stretch n Dust yellow oil cloth or a dry rag until it is spotless.
    This is the part that creates the gap to the mag roller
    6. note: it is NOT neccessary to remove the mag roll - leave it in the housing
    The easiest way to clean the mag roller is with a Scotch Brite green pad ( the same ones you use to clean a frying pan ) and rotate the mag roller as needed and vacumm any toner particles that are left.
    7. now that everything is spotless put back the doctor blade and push it against the mag roller as you tighten the 2 black screws ( removed in step 4 ). There is no adjustment as long as it is snug against the mag roller.
    8. put back the cover - 2 gold screws and 4 tabs
    9. put dev unit and toner back in machine and run Sim 130 to refill dev unit with toner. It can take 5 to 8 minutes to fill up the empty dev unit
    if you're using Kyocera toner your copy quality will be very good.
    • n25an
      • Jul 2008
      • 1030
      #17
      thanks for the info and one last question
      Rule #1
      this sounds good... empty out toner... and clean out any thats there... leave mag roller in... clean..... with frying pan scrubber... could take doctor blade off but don't have to if I dont want to just get mag roller clean... pack it all back up... and then go... and no need to worry about the actual developer powder... just stick it back in machine and the copier will do the rest in sim mode 130... and all should be right with the world...
      sounds good... thanks a million
      Sad To Say I Don't Have a Life
      I do this stuff on the weekends too
        • 22979
        #18
        Originally posted by n25an
        ...... and no need to worry about the actual developer powder...
        monocomponent = no developer (or only developer, however you want to think of it.). There's only one component, the stuff in the toner cartridge.
        • kyoceradude
          The Great Gazoo
          • Aug 2006
          • 442
          #19
          The only problem with cleaning a DV unit, is that the doctor blade can be damaged if not careful. Do not use anything abrasive on it. Otherwise we have had success cleaning units in a pinch. Your best off replacing it under warranty if your PM's are on schedule.
          My mission here on Earth is to help all you Dum-Dums!
          • aabarnes1
            • Mar 2009
            • 620
            #20
            Martin Yale brand Roller Rejuvenator:
            Rubber Roller Cleaner and Rejuvenator - 13 oz, Equipment
            Works great on metal like fuser rollers & developing cylinders, rubber tires (what it's designed for), and even plastic covers. Note: when cleaning tires don't expect the towel to start coming away clean. I literally removes a glazed layer of rubber, and will continue to remove rubber as long as you rub. =^..^=
            'tire' is spelt TYRE in Inglish! If this shit is designed for rubber and plastic why tf are you using it on metal, doh!
            Grant me the serenity to accept the things I cannot change.
            • aabarnes1
              • Mar 2009
              • 620
              #21
              Rule #1
              Why would you remove a doctor blade, you're askin for fuckin problems.
              • aabarnes1
                • Mar 2009
                • 620
                #22
                So then based on everything I am hearing my dull copies were either
                1. caused by not realigning the magnetic cleaning blade correctly
                2. the mag roller not getting the alcohol completely dried out...
                I think the fool that said that didn't get the alcohol dried out.
                  • 22979
                  #23
                  I just cleaned up a Falcon II developing unit today. My symptoms were black lines and voids in the feed direction.
                  First, I took off the top of the unit. You might as well remove the white idler gear off the front. It will fall off while you're working. I also removed the doctor blade. The magnet in the blade pulls it up tight to the roller and the ends hit metal stops at the developing roller bearings. There is no adjustment.
                  Second, I dumped as much toner as possible, then vacuumed out the rest.
                  Third, I cleaned the roller with roller rejuvenator, then wiped it down with alcohol. I also cleaned the doctor blade (now much cleaner, lots of scrubbing).
                  Fourth, I reinstalled the doctor blade, white gear, and poured in the remaining toner. Then reinstalled the top cover.
                  Fifth, I reinstalled the developing unit & ran drum refresh twice. Not because the drum needed polishing, but because that gets me about 10 minutes of developing agitation.
                  Sixth, I removed the developing unit and dry-wiped the entire surface of the developing roller to clear up some pretty heavy mottling. At this final stage you must only rotate the developing cylinder downward, so you don't cause any additional mottling. As you wipe, you'll see the roller get a nice thin translucent coating of toner.
                  The resulting prints are as good as new. =^..^=
                  • n25an
                    • Jul 2008
                    • 1030
                    #24
                    so in step 1 you removed the white roller, top cover and doctor blade
                    in step 2 you emptied the developer of toner and vacuumed what you couldn't pour out.
                    in step 3 with roller still in slot you cleaned doctor blade which has been screwed out... you clean roller which has not been uninstalled
                    in step 4 you reinstalled the doctor blade the white gear and the remaining toner...
                    ok what toner??? this sounds like a starter of some kind...
                    in step 5 you reinstalled the developing unit and ran 2 drum refreshes
                    in step 6 you got mottling... so you uninstalled developing unit...took of top and white roller and rotated developing roller clockwise or counterclockwise... or away from or towards... rotating down is relative??? I am thinking counter clockwise
                    • kyoceradude
                      The Great Gazoo
                      • Aug 2006
                      • 442
                      #25
                      OUI!
                        • 22979
                        #26
                        so in step 4 you reinstalled the doctor blade the white gear and the remaining toner...
                        Nope! It's just the toner I dumped out. I could throw it away, but why?
                        [/QUOTE]in step 6 you got mottling... so you uninstalled developing unit...took of top and white roller and rotated developing roller clockwise or counterclockwise... or away from or towards... rotating down is relative??? I am thinking counter clockwise[/QUOTE]
                        I guess it would be clockwise as viewed from developing unit rear. If you've been around a few developing units, you'll know that the developing roller should be turned in the direction that the doctor blade levels off the toner on the roller, and dumps the excess inside the unit. If you turn it the wrong way it will dump in your shoes.
                        So my advice is turn the developing roller in one direction, and then look at your shoes. If there's no toner on your shoes you're turning in the right direction.
                        • n25an
                          • Jul 2008
                          • 1030
                          #27
                          So my advice is turn the developing roller in one direction, and then look at your shoes. If there's no toner on your shoes you're turning in the right direction.[/QUOTE]
                          thanks a million... just wanted to clear up some things...
                          • n25an
                            • Jul 2008
                            • 1030
                            #28
                            here is what I have been doing and it works.... goto homedepot and get 3m proffessional scour pads (heavy duty...) cut a small square... take out the developer.... don't open anything... just turn mag roller via the gear... then use the small square of scour padd and rub along the length of the roller... turn.... rub.... turn.... rub.... until.... the roller looks ok..... then put it in a machine.... turn it on... and check results.... this has been used to get rid of white spots on developer roller and lines on developer roller... keep in mind that if the marks on the mag roller are very deep this might not work... becuase the roller is shot... but nine times out of ten... it will...
                            • n25an
                              • Jul 2008
                              • 1030
                              #29
                              final note:
                              conclusive steps...
                              take top off developer unit...
                              empty out the toner...
                              vacuum out till empty
                              you do not need to remove the cleaning blade...
                              just make sure you are using the vacuum atttachment which is a brush...
                              spin the magnetic blade and vacuum until it is shiny and new...
                              then take a clean and dry piece of cloth and rub until the marks come out...
                              if your finger touches the roller... you need to clean that spot off with a dry cloth... it will leave a wierd mark on copies...
                              if after rubbing you still have marks that will not come out... try scotch brite pads... they will leave a funny scratch on the developing unit but will not affect copy quality...
                              if youhave deep scratches in your magnetic roller... its shot...
                              if you get the mag roller clean...
                              there is no toner....
                              then your next step is to put the unit back together...
                              stick it in the copier
                              do a developer refresh
                              and you are done...
                                • 22979
                                #30
                                You're just now finishing that call? =^..^=
