km 4030/4035 developing unit (refurbishing it)
  • n25an
    • Jul 2008
    • 1030
    crazy question.:
    Is there any way to clean the magnetic roller in the developer unit without it losing its charge?
    Atleast thats what it seemed like to me.
    I popped open a developer unit
    cleared out the toner
    cleaned off the magnetic roller with some alcohol
    and copy quality got very bad
    it was about the quality of a paper that had been copied that got wet and had a very light impression
    this was a definite step down from what I was getting before...
    next I tried to isolate the problem by switching this magnetic roller with the magnetic roller in another developing unit... I got the same result... the magnetic roller definitely died.
    this is ok because they were junk anyway but i was checking out some statements about refurbishing developers in this forum.
    Is there any way to clean the developer magnetic roller without it losing magnetic charge
    I confirmed that it was a bit weaker by checking how attracted the magnetic cleaning blade was to the roller
    Sad To Say I Don't Have a Life
    I do this stuff on the weekends too
  • Jules Winfield
    • Jul 2009
    • 821
    I wouldn't say that alcohol causes a mag roller to lose it's magnetic properties, but I've always used dry rags and a vacuum.
    But I'm trying, Ringo. I'm trying real hard... to be the Shepherd.
      • 23008
      On Canons and some Ricohs it's necessary to clean the mag rollers occasionally. Roller Rejuvenator or trichorethylene (if you can still get it) works quite nicely. Just be sure to vacuum the unit as clean as possible beforehand, and rinse the roller with alcohol afterwords and wipe dry. On a Canon NP 6030 you can count on ~75 crappy low-fill copies until the mag roller has completely cleared the alcohol. Since the KM-4035 is monocomponent also, it should work about the same.
      The magnetism in the mag roller is not at any risk during cleaning. =^..^=
      • blsquires
        • Nov 2008
        • 342
        silly question
        did you do a 130 devsetup after you got it all back together .
        i have cleaned loads of these mag rollers with brasso and had no ill efects .
        brian
        • Doedee316
          • Aug 2009
          • 11
          Cleaning the mag
          If there is rotational bands on the mag, I take a scotch brite pad with green side down and clean it. It doesn't effect the mag and it works great.
          Doedee316
          • 10871087
            • Jan 2005
            • 1062
            alcohol won't kill a magnet, you can clean the mag roller with a dry rag most ot the time w/good results. If in doubt, get a new developing unit, they are cheap.
            • n25an
              • Jul 2008
              • 1030
              mag roller rejuvinator
              I will check this out... if anyone knows of the exact product name... I would be interested...
                • 23008
                Martin Yale Rubber Rejuvenator
                Martin Yale brand Roller Rejuvenator:
                Rubber Roller Cleaner and Rejuvenator - 13 oz, Equipment
                Works great on metal like fuser rollers & developing cylinders, rubber tires (what it's designed for), and even plastic covers. Note: when cleaning tires don't expect the towel to start coming away clean. I literally removes a glazed layer of rubber, and will continue to remove rubber as long as you rub. =^..^=
                • banginbishop
                  grumpy old git
                  • Oct 2007
                  • 894
                  Question: Did you take off the doctor blade because i did that and i could not get it back to the correct spec and i had very poor copy quality. As these are non serviceable items kyocera dont give you the doc blade gap diameter.
                  I've rebuilt Sharp dev units with no problem setting the doc blade back to its original setting with a feeler gauge but i've gave up with the kyocera.
                  Sharp mag rollers had magnets in them (dont know about kyocera) and if there broken and also put in back to front it gives you problems also.
                  Incontinentia Buttocks
                  • n25an
                    • Jul 2008
                    • 1030
                    kyocera doctor blade diameter
                    Can that really cause an issue... I thought you just pulled them off cleaned the them up and stuck them back on... I did not know you had to worry about the distance from the blade to the mag roller.... man why the heck doesn't kyocera go over any relevant stuff in their training classes....
                    • n25an
                      • Jul 2008
                      • 1030
                      fuser and developer roller rejuvinator
                      does this stuff really work...???
                      Will it work on the fuser pressure roller that gets all crumpled?
                      Will it work on the fuser roller with the heating element running through it?
                      and it really works for the mag rollers???
                      this does say rubber roller cleaner... ???
                      If you are sure... I will give it a shot...
                      • n25an
                        • Jul 2008
                        • 1030
                        step by step guide
                        brian
                        how do you clean a km 4035 developer step by step... ???
                        This way we are all on the same page...
                        lets see if I missed something...
                        • n25an
                          • Jul 2008
                          • 1030
                          So then based on everything I am hearing my dull copies were either
                          1. caused by not realigning the magnetic cleaning blade correctly
                          2. the mag roller not getting the alcohol completely dried out...
                            • 23008
                            Yes, and Yes.
                            Also add #3. mag brush height misadjusted.
                              • 23008
                              I'm not fibbin'... =^..^=
