km 2050 with c4000 code
  • copysys
    • Aug 2008
    • 41
    i have a km2050 with a c4000 trouble code. the c4000 code points to the laser motor. is a bad laser motor normally the problem associated with this code? or should i be looking somewhere else. Thanks in advance for any help
  • kyoceradude
    The Great Gazoo
    • Aug 2006
    • 442
    Before the code happened did the customer complain about a loud whining noise? If so Kyocera had an extended warranty for laser replacement on Gen Tech bulletin #66 for laser failure, but that expired about a year ago. If the code resets and is intermittent, it can be a main charger/drum failure. If the code keeps coming back, its a laser.
    My mission here on Earth is to help all you Dum-Dums!
    • Craigdumass
      • Jun 2009
      • 61
      Nice reply, I have replaced three lasers in the past 6 months on these, I usually check the CW unit first before I replace the laser. When the Corona unit start arching to the drum in many cases it will throw the laser code along with it.
      • tswanic
        It is usually the LSU but I have seen a dirty or shorted primary corona grid arch to the drum
          • 23009
          I've replaced a few lasers for C4000. No excessive noise, but the mirror motor bushings were snug.
