KM 6030 (utax cd1060) C4200 code
  • aabarnes1
    • Mar 2009
    • 620
    I have an error code 4200,I,ve tried the ferrite core, replaced the laser, main board and motor(driver) board to no avail. machine powers on to 'ready to copy' state, does one copy then up comes this error code, any ideas would be greatly appreciated. There is 650k only on this box and it had a full pm kit at 495k.Thanks.
    Grant me the serenity to accept the things I cannot change.
  • Craigdumass
    • Jun 2009
    • 61
    There is a problem with the way the wire harness is wired you should call your technical representive because I am not sure if you have to order a new harness or just have to reroute the existing one.
    • JSC
      Gimp
      • Dec 2006
      • 618
      Craigdumass is correct, I had the same thing. I rerouted the the control wiring harness to the laser and have not had a problem since.
      The gene pool could use a little chlorine.
        • 23009
        What firmware level are you at? There were 3 or 4 consecutive firmware releases that generated 4200 codes spontaneously starting with v. 352. The last two releases seem to be clear of obvious bugs (most recently 8-11-09). At least none have come up yet. =^..^=
        • B0265
          • Jan 2007
          • 718
          There should be a (European) tech bulletin, 2FB-0095 (8619) about the harness but I can't find it. Does anyone have this bulletin?
            • 23009
            8619/2FB-0095
            I think this is what you want:
              • 23009
              7393/ 2FB-0024
              Also take a gander at this one:
              • B0265
                • Jan 2007
                • 718
                That's the one, thank you.
                • aabarnes1
                  • Mar 2009
                  • 620
                  Sorry I took so long to reply to this, since original post I have had two further instances of this code. The first machine was indeed noise from the transfer unit and once mod was done she worked perfectly. The second was a case of re routing the laser harness and the third was solved with a ferrite core. Now my only problem is the jam code 60! yes I've seen the TB and applied the procedure-even fitted new mylars and feed/sep rollers from next gen machines but still I'm dogged by regular misfeeds in the branch section.
                    • 23009
                    How many prints on the duplex switchback roller? It should be a PM part since most don't last more than 550K. You'll see J60, J61, J62, or J63. There is a simple test, and a more accurate test.
                    The simple test: lay your 6" metric scale centered in the same direction as the shaft, on top of the roller. If the end of the ruler touches the lower guide at the rear, the roller is too worn.
                    Accurate test: Cut a strip of paper ~5mm wide and 100mm long. Wrap it around the rear part of the roller and mark the paper across both layers. Measure the distance between the marks. 64.0mm is worn out. Original circumference was ~ 65.3mm. =^..^=
                    • aabarnes1
                      • Mar 2009
                      • 620
                      I'll post back soon.
