KM-1525 copy problem
  • Warstg_20
    • Sep 2009
    • 72
    Yesterday i service a Km-1525,. the problem is horizontal white lines,.
    i check the gear of developing, and replaced it, then check the developing MAGNET, then found out that the MAGNET developing have a blank around 2mm in wide that doesn't have a developer on it.... So i think, that is the problem... that causes white lines on the copy..
    anyone have suggestion on how were i fixed this?
    thanks
    • 23009
    I'm not familiar with your KM-1525, but I think I'd probably replace the developing unit.
    • Absurd
      Just a brick in the wall
      • Oct 2007
      • 118
      i have seen similar problems where the charger wires get to loose and start to spin inside the charger like a jump rope and cause the white lines. these are like the old km-2030 or Ai-3010's.
      Southern Duplicating of Mississippi
      PSN: DrAbsurd (if you know you know)
      "If you love wealth more than liberty, the tranquility of servitude better than the animating contest of freedom, depart from us in peace. We ask not your counsel nor your arms. Crouch down and lick the hand that feeds you. May your chains rest lightly upon you and may posterity forget that you were our countrymen." [Samuel Adams]
      • assistenza
        Anjin
        • Mar 2008
        • 20
        Laser mon ami ?
        • jewen25
          • Mar 2009
          • 197
          yah maybe that the problem,clean and developer,if not check the scanner
          ERROR HELP ME AND HELP YOU
          • Warstg_20
            • Sep 2009
            • 72
            thanks for your reply...
            I already solve this problem i replace magnetic roller...
            thanks again
