Need help KM2035 with crease paper in the fuser area
  • siraphop
    • 54
    hello all tech,
    please help I have a crease paper though there was cause in the fuser section. already changed upper and lower roller picker finger .
    still the same come with the crease I assume that maybe in the temperature control by using U161 adjustment .
    anybody know as this problem could be solved by use U161 ?
    thank to all
    pop
  • 10871087
    • Jan 2005
    • 1062
    Did you replace for entire fuser assembly or just the claws (picker fingers)?
    • siraphop
      • 54
      thanks fo your help 10871087
      I have only replace upper and pressure roller and 5 picker fingers.
      • Jules Winfield
        • Jul 2009
        • 821
        You might also want to take a look at the black plastic guide on the left door. It's the spring-loaded one with the white plastic idle pulleys. I've seen these get warped from the heat of the fuser and bow out. This causes the copies to either skew going into the fuser or just jam outright.
        But I'm trying, Ringo. I'm trying real hard... to be the Shepherd.
        • Absurd
          Just a brick in the wall
          • Oct 2007
          • 118
          ive seen 2 things cause wrinkles in paper on these. the first is the fuser unit (always looked like it was a press roller issue) the second is paper in the drawer crooked or off center.
          Southern Duplicating of Mississippi
          PSN: DrAbsurd (if you know you know)
          "If you love wealth more than liberty, the tranquility of servitude better than the animating contest of freedom, depart from us in peace. We ask not your counsel nor your arms. Crouch down and lick the hand that feeds you. May your chains rest lightly upon you and may posterity forget that you were our countrymen." [Samuel Adams]
          • siraphop
            • 54
            A big thanks for all .
            • siraphop
              • 54
              The problem is solved.there was a small bit of toner built up on the paper paht before the fuser area,paper with a small loop when hit the block.
