KM3050
  • TA_Tech
    • 76
    KM3050
    Hi Gents and Ladies
    I have a problem where the machine's panel locks up, especially if you move it up or down. Sometimes even simply just through normal use. Any Ideas what could cause this?
  • Jamiesdad2
    • May 2009
    • 29
    Panel locking up
    I recently had the same issue. I replaced The Wire-Main Panel IF part number 302GR46520. It is 1 of the cables that runs from the op panel to the engine pcb. The part is currently on back order.
    Hope this helps.
      • 23009
      Look at this post:
      http://www.copytechnet.com/forums/ky...050-error.html
