Taskalpha 500
  • stevee104
    • Mar 2007
    • 214
    Taskalpha 500
    This machine on long copy runs pauses for about 10 seconds about every
    12 to 15 copies.I have did all sims and calibrations and firmware updates.
    I am making copies in auto mode and they have some color text and no photos.
  • peterepeat
    • 84
    You may want to check the filters.....ALL of them. I can't remember exactly how many there are. It sounds like heat is building up inside the machine & it's constantly recalibrating. Kyo's need to breathe.
    • 10871087
      • Jan 2005
      • 1062
      Is this a new machine that has always done this or is this a new issue on a machine that has been out for a few months?
      Format the hard drives??
      • vikingmita
        • Nov 2008
        • 163
        -had a customer who had a FS-C5030 in a corner and an airconditoin fan next to it blowing straight at the printer. moved it, and had to do colour calibration
        • Realtech
          • Oct 2009
          • 103
          Taskalfa 300ci
          I have the same issue with the taskalfa 300ci and my boss is not happy at all with this .It's a new machine!!!!!!!!!!!!!!!!!!!!!!!
          How I going to explain this to customers when they start complaining.
          • dickierock
            • 252
            Hi, you can set the calibration cycle to "long" in the system menu.It should make an improvement.
            • Jules Winfield
              • Jul 2009
              • 821
              You have to recalibrate those model machines whenever they are moved anyway...
              But I'm trying, Ringo. I'm trying real hard... to be the Shepherd.
              • tmaged
                Owner/Service Manager
                • Oct 2008
                • 1890
                I did that on a new machine last week. It's only been in about a month & has about 4k total on it. As the original poster stated, it'd run about 12-15 copies & calibrate for about 3 minutes. I'm wondering if the humidity has anything to do with it as it's very low right now.
                The vitals are as follows Temp 23, Humidity 14, Internal 24, Internal 2 0, Internal 3 24.
                Hope that helps !
                -Tony
                www.dtios.com
                Become a fan on Facebook
                • tmaged
                  • Oct 2008
                  • 1890
                  UPDATE: In U464 Set Interval Calib Print Rate, it seems this is for % of coverage on the page. My customer is running about 20-30% coverage on their fliers. 10% is the default for calibration. I bumped this sim up & it stopped calibrating. This obviously could be detrimental not maintaining quality. The sim is written kind of ambiguously so it really hard to say exactly what it's doing / looking for. Hopefully this will help someone else out.
                  Hope that helps !
                  -Tony
                  www.dtios.com
                    • 23009
                    The problem I've had is getting it to calibrate more often, not less. If it maintains the quality, I'm ready to take on any verbal challenges to explain away the need to calibrate.
                    It's not an analog! There are a lot more things happening here than a main motor chugging away. Now if you don't care what the prints look like, I can live with that too. =^..^=
                    • tmaged
                      • Oct 2008
                      • 1890
                      You having quality issues ?
                      Hope that helps !
                      -Tony
                      www.dtios.com
                        • 23009
                        Not any more. I set all my TASKalfa machines to "Custom" Calibration Cycle. With the settings that I have been using it calibrates every 25 pages for 12 seconds. Once it is explained why the machine does this, I get very little in the way of complaints. =^..^=
