Cleaning solution for kyocera copiers
  • n25an
    • Jul 2008
    • 1030
    Whats the best product to buy to clean copiers when the toner is ground into the white plastic covers?
    Sad To Say I Don't Have a Life
    I do this stuff on the weekends too
  • siraphop
    • 54
    water
    powdered detergent with water
      • 23009
      Try this:
      I've been using it for years. It's safe and effective on most surfaces including your hands. It does a great job on PVC covers (as long as they haven't been chemically etched with something else). You can apply this product full strength up to (5) times to the same area before rinsing with water. After (5) applications there is a risk of etching the surface.
      Some techs dilute it 50/50 with water, for use on ink, coffee, and other water based stains.
      Since I've started using this product my hands & nostrils no longer crack & bleed. I strongly recomend it. =^..^=
      • n25an
        • Jul 2008
        • 1030
        cleaning solution update
        Try this:
        I use degreaser but on the toner and scuffs I just used a steel brush.... it takes off the plastic and looks worse but if you get a cloth with degreaser on it and rub in the same spot you just brushed you will see a dramatic improvement...
        quick note... do not use steel brush on metal part of copier...
        and you are actually removing plastic when doing this so do be gentle to the copier...
        • 10871087
          • Jan 2005
          • 1062
          Mr. Clean Magic Eraser works great on covers.
          • Jules Winfield
            • Jul 2009
            • 821
            Simple Green works pretty well. If the covers are really bad you can use rubbing compound followed by Simple Green.
            But I'm trying, Ringo. I'm trying real hard... to be the Shepherd.
