KM CS 3050 Copy Quality Problem ?
  • Executechs1315
    • Aug 2009
    • 11
    I have 2 3050's that have been well maintained, cleaned etc... Both have about 400K Prints on them. The copies/prints have marks on them that look like a Bicycle ran over the page. Example: ( <<<<<<< ) I am guilty of using Katun Generic Toner, usually this company has high quality toner and never had a problem with them.
    After a good cleaning the problem goes away, but recently it coming back more frequently.
    Has anyone seen this in the field.
  • kyoceradude
    The Great Gazoo
    • Aug 2006
    • 442
    You answered your own question, generic toner. Also @ 400k a pm is needed replacing the dv, drum, fuser and tfr roller. Has that been done?
    My mission here on Earth is to help all you Dum-Dums!
    • Jules Winfield
      • Jul 2009
      • 821
      ^ Took the words right out of my mouth...
      But I'm trying, Ringo. I'm trying real hard... to be the Shepherd.
        • 23009
        What your probably seeing is called 'mottling' in Canon terminology.
        It only happens with mono-component toner. If the mag roller is touched with your fingers, you'll leave enough finger oil to create a clump of toner on the roller that will create a re-occurring artifact every 35.75 mm. You can dry wipe the affected areas of the developing roller with a cotton towel or webril. High humidity can create the same effect.
        Generic toner is much more susceptible to this problem. =^..^=
        • n25an
          • Jul 2008
          • 1030
          tire tracks or tread marks...
          your charger has gone bad...
          on the km 2560/3060
          you get a toner cloud over the whole page.... when this happens...
          Sad To Say I Don't Have a Life
          I do this stuff on the weekends too
