Problem with getting KM3050 to send scan to email
  • teigas
    • Aug 2025
    Just bought a KM3050, but i have some issues, i hope someone could help me with.
    Hooked it up, with a network cable to my router, and added the printer on the different computer, and added drivers.
    Was in command mode and setup my smtp settings, and email settings, but when i try to push the button send to email, and enter my email, it just get an error 1505 or somthing, and says that it cant send.
    When i added the server settings, and push test, it says they are working.
    The only thing i havent done is what stands her:
    It stands that For Scan to Email, DNS server is required. , is this true? Will it not work, if i do not put some values in her?
    How do i find out what my dns values for my email server is?
    • 23009
    If you temporarily set the machine to DHCP it will pick up WINS and DNS all by itself.
    A simple way to acquire the DNS is to put your laptop on the network set to DHCP. Once connected, go to a command prompt and enter
    C:\Documents and Settings\John Smith>ipconfig/all then Enter. The DNS will be listed.
    The error code can help diagnose your connection problem. There is no "1505 or something". But if it is 1105, SMTP is not yet enabled in the web interface. I believe that the default is Off. =^..^=
    • teigas
      Once again thanks for the reply.
      Regarding dns, is it my internet providers dns it needs? Or is it the SMTP servers dns it needs? I got my email adress hosting from an provider@web hotel , so the SMTP server dns would be diffent from my home office internet providers dns. So wich of theese adresses is needed to get it to work?
      I am pretty sure i got the error you stated.
      But in command center , i went under email, and under SMTP , and general. And added SMTP protocol to on, and entered my details.
      After wards it sendt the information to the printer, could it be that the printer havent recived them?
      Is there any way on the printer to check if the settings have been sendt over?
      I was on a simular page as this:
      On page 5.
      But i diddent apply the dns server, could that cause the error you stated?
      • ss12
        • Jul 2008
        • 289
        in the reply address have you put in the same domain name.forgot to do this once and it would`nt send.hope this helps
          • 23009
          I haven't had much luck hooking up to external SMTP servers. I won't be able to help with that. =^..^=
          • tmaged
            Owner/Service Manager
            • Oct 2008
            • 1888
            A DNS server is required to resolve the hostname of the mail server, if that's what you're using. Like Blackcat said, open the cmd prompt & type ipconfig/all on the network the copier is on. This will show the DNS servers. You can always get around using DNS by pinging the mail server. It will reply with the IP address and you can use this where you'd input the mail server.
            All a DNS server does, is look up the IP address of whatever you want. You'd never remember Google's address at 156.154.112.163 so when you type in www.google.com it goes to the DNS server & says hey what is the address for www.google.com It works the same when using the host name of the mail server. mail.domain.com needs to be converted to an IP address. If you use the IP address, you don't need DNS. DNS is good in case the IP address of the mail server ever changes though.
            Depending on the mail server, you'll need a valid from address in the senders email address.
            Hope that helps !
            -Tony
            www.dtios.com
            Become a fan on Facebook
            • teigas
              Where in the adress book on the printer itself?
              Or in command mode in email settings?
              • tmaged
                • Oct 2008
                • 1888
                In the Command center. That's what I was talking about using a valid email address. Most servers require this to keep from sending spam.
                Hope that helps !
                -Tony
                www.dtios.com
                • teigas
                  I used a valied email adress, but i used the host name, not the ip adress, and haddent added a dns server, guess thats why it diddent send.
                  But when i test ipconfig /all i get the dns of the network i am hooked up to, but that is 192.168.0.1 , would that work for dns? Or do i need an external dns server?
                  • tmaged
                    • Oct 2008
                    • 1888
                    192.168.0.1 is probably the IP address of the router and it should work. Is this the same network that the copier is on ?
                    Hope that helps !
                    -Tony
                    www.dtios.com
                    • teigas
                      Jepp, its the ip of the router, and it also works as dhcp server, and recives internett.
                      • vikingmita
                        • Nov 2008
                        • 163
                        smtp protocol set to on? and port no to 25?
                        • teigas
                          Added a dns server, and redid all the smtp settings, and it worked thanks
                          • mmechura
                            • May 2008
                            • 43
                            email settings
                            Are you on a domain or workgroup? If you are on a workgroup I sincerely doubt that your DNS server is at the address that you claim. Unless you are on a domain and rarely at that the address would not be the 192.xxx.xxx.xxx For example if you are getting your internet from Verizon your dns server(s) would be 4.2.2.1 or 4.2.2.2 or 4.2.2.3 the 192.168.0.x address is a private network address and would not be resolving names. In a small domain, unless you changed the IP of your router and were going against normal setup protocol, the DNS server would be the same as the file server ie. 192.168.0.10
                            Below is a copy of my ip configuration - Note DNS servers are
                            167.206.xxx.xxx
                            Microsoft Windows [Version 6.0.6002]
                            Copyright (c) 2006 Microsoft Corporation. All rights reserved.
                            C:\Users\Mark>cd\
                            C:\>ipconfig/all
                            Windows IP Configuration
                            Host Name . . . . . . . . . . . . : Business
                            Primary Dns Suffix . . . . . . . :
                            Node Type . . . . . . . . . . . . : Hybrid
                            IP Routing Enabled. . . . . . . . : No
                            WINS Proxy Enabled. . . . . . . . : No
                            Ethernet adapter Local Area Connection:
                            Connection-specific DNS Suffix . :
                            Description . . . . . . . . . . . : Realtek PCIe GBE Family Controller
                            Physical Address. . . . . . . . . : 00-22-68-5A-ED-2D
                            DHCP Enabled. . . . . . . . . . . : Yes
                            Autoconfiguration Enabled . . . . : Yes
                            Link-local IPv6 Address . . . . . : fe80::a58a:f4d2:8227:b3c2%11(Preferred)
                            IPv4 Address. . . . . . . . . . . : 192.168.1.101(Preferred)
                            Subnet Mask . . . . . . . . . . . : 255.255.255.0
                            Lease Obtained. . . . . . . . . . : Tuesday, January 12, 2010 10:40:03 AM
                            Lease Expires . . . . . . . . . . : Thursday, January 14, 2010 8:24:32 PM
                            Default Gateway . . . . . . . . . : 192.168.1.254
                            DHCP Server . . . . . . . . . . . : 192.168.1.254
                            DHCPv6 IAID . . . . . . . . . . . : 184558184
                            DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-11-B8-E7-E4-00-22-68-5A-ED-2D
                            DNS Servers . . . . . . . . . . . : 167.206.245.129
                            167.206.245.130
                            NetBIOS over Tcpip. . . . . . . . : Enabled
                            Tunnel adapter Local Area Connection* 6:
                            Media State . . . . . . . . . . . : Media disconnected
                            Description . . . . . . . . . . . : isatap.{A698A469-6E31-4647-B4A8-232D807DE
                            11C}
                            Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
                            DHCP Enabled. . . . . . . . . . . : No
                            Tunnel adapter Local Area Connection* 7:
                            Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
                            Physical Address. . . . . . . . . : 02-00-54-55-4E-01
                            Good Luck
                            • teigas
                              Just pinged my hosts host name, and added the ip, then i diddent have do add dns server.
