kyocera km 1500
  • HaSSaN010
    • Aug 2025
    kyocera km 1500
    hello
    i have km 1500 code error c-6 400
    or 400 c-6
    How do I fix wrong.
    Is there a program, how to go there
    I really appreciate your help me ,,..,,
  • zaza
    MECANOGRAPHE
    • Mar 2008
    • 1095
    more information ..please ...
    Originally posted by HaSSaN010
    hello
    or 400 c-6
    How do I fix wrong.
    hello friend ..well in km 1500 they not have the code error c-6 400 or 400 c-6 ...please to be clear ...because it have only ..c6400..so you can sure for this code error ...if you need more explain contacted me from my mail ...mecanopharme@hotmail.fr ...l can healpe you my friend ..salam ...
    BEST TECHNICIAN . NICE PEOPLE .
    • zaza
      MECANOGRAPHE
      • Mar 2008
      • 1095
      hello
      or 400 c-6
      How do I fix wrong.
        • 23009
        C6400 is a Zero-Cross Error. That means that the machine's power supply has detected a poor ground that interferes with the machines heat lamp control circuits. You'll need to do two things.
        1) Contact a qualified electrician to resolve your dirty AC power.
        2) Reset the error in simulation 163. This can be found in the manual.
        Good luck. =^..^=
        • happicopy
          • 51
          press stop/clear,print , light, stop. 000 will appear Enter '163' using the up/down keys n the counter key then press print key CLR will appear press print key twice then --- will appears, machine will reset it self wait for a while. you 'may' have a bad heater lamp if code reappears or you have defective thermistor and bad worn out fuser roller
