Km- 5050 Device Asset # ?
  • nodle
    • 142
    I have a customer that wants to indicate the location of the machine on the Kyocera Command center page, by inputting the location in the Device Asset# spot. Unfortunatly we are not having any luck finding how to cahnge the Device asset #. Can any body give me some direction. I'm normally a Ricoh tech, and was trained on these things over 2 years ago. I've only worked on 6 of them since I was trained. Any assistance wil be greatly appreciated.
  • Jules Winfield
    • Jul 2009
    • 821
    In Command Center, it's listed under Management\SNMP\SNMPv1/v2c\Settings. Look for "sysLocation:"
    I'm sorry, I misunderstood your post. To change "Asset number", Open up KMnet Viewer and add the device in question. Then, right-click on the device and go to "Advanced", then "System Settings". From this page you will see the "Asset number" setting and will be able to change it.
    But I'm trying, Ringo. I'm trying real hard... to be the Shepherd.
      • 22999
      I've got one customer that has changed the machine's host name to their asset number. I suppose it makes no difference to me. =^..^=
      • nodle
        • 142
        Jules, am i able to access the KMnet veiwer from the command center? Sorry for the silly questions. Like I said haven't touch many of these since being trained. we just havn't sold many.
          • 22999
          It's the reverse. Command Center is the machines web interface, and you have a shortcut to the web interface in the admin utility KM-Net Viewer. =^..^=
          • Jules Winfield
            • Jul 2009
            • 821
            Kmnet Viewer is a utility that comes with all Kyocera copiers/printers. You can find it on the same CD that the drivers are on. KMnet Admin is another utility offered free by Kyocera, however this is a server-based utility and is way more complicated to set up. For something like you described, just install KMnet Viewer on your laptop (if you have one) and run it from there. Otherwise, you'll have to run it from one of the customer's PCs.
            • nodle
              • 142
              OK Thanks to both of you. Just on last question can the customer down load the operation manuals from the command center? in case he has more questions.
              • Jules Winfield
                • Jul 2009
                • 821
                Sort of. There is a link in Command Center called "Download Drivers" that goes to Kyocera's main user download area. From there you can get drivers, manuals, brochures, etc...
                • nodle
                  • 142
                  That's what i thought . Thank you. You have been a great help.
                  • Jules Winfield
                    • Jul 2009
                    • 821
                    No problem...
                    • tmaged
                      Owner/Service Manager
                      • Oct 2008
                      • 1869
                      There is also an Equipment ID field in the command center under the advanced tab>Maintenance
                      Hope that helps !
                      -Tony
                      www.dtios.com
                      Become a fan on Facebook
                      • Jules Winfield
                        • Jul 2009
                        • 821
                        Yeah, but they aren't the same thing. The Equipment ID field doesn't show up on the home page and is only used when the machine sends maintenance emails.
                        • tmaged
                          • Oct 2008
                          • 1869
                          He just said he wants it in the command center.
                          Hope that helps !
                          -Tony
                          www.dtios.com
                          • Jules Winfield
                            • Jul 2009
                            • 821
                            He also said that he wanted it listed under "Asset #"...
