C2351 on TASKalfa
    • 23010
    C2351 on TASKalfa
    Ok. It started out simple enough. Gray background on prints and copies. I found something sticky on the transfer belt. Each time it comes around it snags on the transfer cleaning blade. No sweat. So I put it all together and I get a surprise: C2351.
    I've seen the bulletin, so I order and install first the cleaning motor K, second black drum unit, third engine PWB. It's got v. 8.00 firmware. I've turned the cleaning drive by hand- it turns quite easily, yet in sim U030 'Paper Feed' the motor can be stopped very easily and seems to me to turning too slowly, much slower than the adjoining motor of the same type.
    Along the way I've found a sheared off cleaning auger in the black drum unit, and after the engine PWB a CF18A (must be firmware since a flash solved that). This machine is kicking my butt.
    I thought about the main drive unit, but have not pursued it yet. It a major pain to change, and I'd like a logical reason to do so.
    Does anybody have any ideas? =^..^=
  • Morlock49
    • Mar 2009
    • 166
    I have had to strip down the drive units for the dev and drums, because for some reason grease gets into the phospher bronze bushes and then it gets sticky, putting extra load on the drive motors. I don't know if this might be part of your problem, but I hope it helps.
    Sorry folks, reputation removed by Just Manuals, because he's a sad little wanker
    • tmaged
      Owner/Service Manager
      • 1901
      Sorry I don't have anything constructive to add about your C2351 issue. I was setting up 2 new machines yesterday & got CF18A on both after updating them to V.8. I've used the download that I used yesterday successfully previously. I redownloaded & updated both machines with no problems. Not sure what the deal was.
      Hope that helps !
      -Tony
      www.dtios.com
      Become a fan on Facebook
      • LNorris
        • Sep 2008
        • 645
        either the developer motors or the cleaning motors are shot. there is a tech bulletin on this. i usually replace both developer and both cleaning motors (4 total) since i have the machine apart.
        • Morlock49
          • Mar 2009
          • 166
          If you think the motor is shot check the fuse on the motor pwb. when I have had a shot motor the fuse has been blown every time. the new motors have an uprated fuse
            • 23010
            LNorris, the C2351 specifically indicates the cleaning motor K, which is now new. Are you implying that motors other than the cleaning motor K can create a C2351 code? I don't see the logic in this assertion. =^..^=
              • 23010
              Morlock gets the prize for post #2.
              The tech rep showed up this morning. We changed the other cleaning motor to the new style, no improvement. Then we removed the black drum unit, black developing unit, and hopper assembly, and ran simulation U030 Feed Motor. The cleaning motor K runs, but the male coupler for the black cleaning roller doesn't rotate. Not a twitch.
              It's what I was hoping not to find: conclusive proof that the main drive assembly is bad. I'll pinpoint the damaged gears a followup post. =^..^=
                • 23010
                One final twist. Once the C2351 was gone, the machine powered up but did not recognize the OEM toner cartridges. After only a few copies I got a Replace Black Toner indication. The new cartridge also read as Replace Black Toner.
                After digging through the circuit diagram, it pointed to connector YC26 at the engine PWB. The connectors are really difficult separate from the PWB, and while I was yanking on the harness I partially disconnected the other end where it joins at the rear frame (and heads to the RFID board and toner motors). That was a real head scratcher.
                At any rate, the machine is finally back up and running. =^..^=
                • hobietacker
                  • 7
                  C2351
                  I want three of these for Christmas this year. NOT!!!!! LOL
                  I had streaks coming from the K drum unit. I replaced the K unit and then got the 2351 code. So I switched the K with the Y cleaning motors and the code went away but now as black cat was saying it starts asking for K Toner. I am going for cleaning motors and a sledge hammer. This does not make any sense and A factory rep needs to figure this out.
                  I will be back with the motors and follow up. I did not touch the engine board at all.
                    • 23010
                    Could you have swapped a K cleaning motor with a K developing motor? They look nearly identical, except for the color of the round sticker on the flywheel ... and the part number printed on the part. =^..^=
                    • kyocera.team
                      • Aug 2010
                      • 126
                      c2351 hummm
                      just change black drum i face this problem last week and when i check the drum "k" i find toner and the cleaning roller already broken and there is 4 spring inside the drum unit missing how i dont know any way i changed the k drum and it working fine without any problems by the way yes you can swap a k cleaning motor with k DLP motor
                      good luck
                      • brecht2
                        • Feb 2012
                        • 71
                        Re: C2351 on TASKalfa
                        Hello Blackcat,
                        Today i had a similar issue with a C2351!
                        First i got a C7000. All DV's were full with toner.
                        After vacuuming toner out of the hopper i got a C7101.
                        Anyway after few a reboots i got a C2351.
                        I changed de DV motor K with the CLN motor K next to it =no result!
                        Changed the CLN motor K with a new one= no result.
                        Changed DV K with a new one and Drum K = no result!
                        Engine PWB = no result.
                        Finaly we changed the harness (DV/CLN ->YC16) and the main drive unit from another T/A400ci with the DV and CLN motors on it= Machine WORKED!
                        PS: We checked also the harness if it was pinched but it seems it to be ok.
                        I'm still doubting what the problem could be! The DV/ CLN K motor or the main drive unit??
                        Strange problem but anyway it is solved!
                          • 23010
                          Honestly, after all that I have no idea what was causing what. =^..^=
