Scan from Direct Connected KM-3050
  • dbailey
    I have a Kyocera KM-3050 that had been on a network. It is now connected directly to my computer through a USB to parallel port wire. I can print to it but cannot set up the correct host name, path, etc. so that I can get scans. Do anyone know the process required to set up scanning with this configuration?
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1890
    It won't scan SMB through a USB cable.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
      • 23010
      If you use a crossover cable and have a spare network connection on your PC, you can very easily set up SMB scanning to a folder. =^..^=
