Kyocera Mita KM-2530 waving
  • ronsulit
    • Jun 2009
    • 13
    i have kyocera mita km2530. after i copy more than a hundred copy the next copy to print is waving. please helt. thank you in advance.
  • 10871087
    • Jan 2005
    • 1062
    Can you attach an image/scan of your copy quality problem?
    If the image has a sawtooth pattern you can check the main charge unit and if that doesn't take care of it you can replace the LSU.
      • 23008
      I'd like to see that scan also. It sounds like a laser to me, too. =^..^=
      • ronsulit
        • Jun 2009
        • 13
        ok sir, i will prepared a scan copy. but do you think its from LSU even that for example i copy 1 original let say 500 pieces. so it will only scan once and after a few copy or hundreds the wave will be shown and the wave is different with other pages.
          • 23008
          Yes, that makes sense. The optical scanner only scans the single original once, but the LSU must write the image for each printed page. The longer it runs the more likely that the polygon mirror motor speed could become unstable, distorting the resulting image. =^..^=
