Have just purchased 2 second hand KM6030's. and they are password locked. Can someone please let me know what the machine reset code is so I can start reconfiguring...
KM6030 Tech Reset
Accessing the Job Accounting Screen
Set up job accounting from the Job Accounting screen. Follow these steps to access the Job
Accounting screen.
1 Press the System Menu/Counter key.
2 Press [Job Accounting].
3 Use the numeric keys to enter the
four-digit management code. By default,
the management code is 6000 for the 60
. Accounting screen will
be displayed.
. Turn job accounting on or off as necessary.
2 Select [On] or [Off].
3 Press [Close].
4 Press [End].
When you select [On], the screen for the department ID-code entry is displayed.
When you select [Off], the [Basic] screen is displayed.
Setting Description
On Job accounting is activated.
Off Job accounting is deactivated.
Close
Each Mgt.
T Register/Sett. Job Accountg
Management Job Accntg
OnComment
ABIS
ABIS
Hi Marc,
Unfortunately it did not like the 6000 code. Can't get it happening. If you have any other ideas would be grateful for them.Comment
