KM6030 Tech Reset
  • ABIS
    KM6030 Tech Reset
    Have just purchased 2 second hand KM6030's. and they are password locked. Can someone please let me know what the machine reset code is so I can start reconfiguring...
  • marc
    • Feb 2010
    • 56
    Reset
    If you want to reset push the default setting at the control panel *
    then go to management at the display the access code could be 6000
    after you in turn off management after that close this screen now you good to go
    good luck!!!!
    • marc
      • Feb 2010
      • 56
      Accessing the Job Accounting Screen
      Set up job accounting from the Job Accounting screen. Follow these steps to access the Job
      Accounting screen.
      1 Press the System Menu/Counter key.
      2 Press [Job Accounting].
      3 Use the numeric keys to enter the
      four-digit management code. By default,
      the management code is 6000 for the 60
      . Accounting screen will
      be displayed.
      . Turn job accounting on or off as necessary.
      2 Select [On] or [Off].
      3 Press [Close].
      4 Press [End].
      When you select [On], the screen for the department ID-code entry is displayed.
      When you select [Off], the [Basic] screen is displayed.
      Setting Description
      On Job accounting is activated.
      Off Job accounting is deactivated.
      Close
      Each Mgt.
      T Register/Sett. Job Accountg
      Management Job Accntg
      On
      • ABIS
        Am off to give it a go. Thanks so much ... will let you know if it works!
        • ABIS
          Hi Marc,
          Unfortunately it did not like the 6000 code. Can't get it happening. If you have any other ideas would be grateful for them.
          • marc
            • Feb 2010
            • 56
            Abis, try this 6482
            goo luck!!
            • heera
              • Jul 2009
              • 8
              Using 10871087 maintnence mode, U20 intialize memory all passwords will get reset, if you are not able to reset 6000.
              • marc
                • Feb 2010
                • 56
                Sim 20
                If you execute the simulation 20 don't forget change the simulation 252 back to inch
                simulation 20 change the setting to Europe type
