occasional black background and black vertical stripes in taskalfa ci series.
  • charly
    • 65
    I'm having the same problem in all color series( 250,300,400,500)
    machine updated with the latest version
    according to new update that has not come, fix the issue.
    also accumulate large amount of black toner developer unit
    Machines with less than 100k even newly installed.
    I'm fixing for now with color calibrations.
    the question is what happens to someone else.
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1888
    For background check U131
    If the Control Voltage differs from the Default Voltage by more than 25, the DV unit will probably need replaced. In some cases DV refresh may take care of it. This is usually only the case with black DV units.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
      • 23009
      I agree with tmaged. Also run some U089 gray internal test patterns. If you see a pattern that repeats at 38mm intervals replace the associated charge roller. Then calibrate. =^..^=
      • charly
        • 65
        all this is checked, but on new machines????????
        anyway I got the new firmware.
        • spiderman76
          • Mar 2009
          • 59
          Where you find Kyoceramita service bulletin ? Kyoceramita Italy doesn't issue techinical bulletin ... :-(
            • 23009
            What do you need? =^..^=
            • SwampYankee
              • Jul 2010
              • 20
              Maybe I missed something... but v6.03 is pretty old, and I know a bunch of fixes were made for CQ weirdness in v9/9.01, including some new options for toner control, BW/Color usage balance, and AC calibration.
              Yeah, I missed something... like the fact the thread was 6 months old. :LOL:
