FS-1116 MFP scaning problem
  • kaborwen
    • Feb 2010
    • 146
    Hello!
    I have a problem scanning with the FS-1116 MFP. When I try to scan it says "error scan". I checked the cable, print and copy, no problem.
    What can I do please?
    • 23010
    Let's start with the basics. What kind of scanning is this? SMB, FTP, email, TWAIN? TCP/IP or USB? =^..^=
    • vikingmita
      • Nov 2008
      • 163
      fs-1116 is usb, no network, so this is stricly a software-problem.
      • kaborwen
        • Feb 2010
        • 146
        FS-1116MFP
        It's USB 2.0. So Witch software? Windows or scaner software? Beacause I Uninstall and reinstall scaner software, but it's still the same error.
        • Charles
          Originally posted by kaborwen
          Hello!
          Hello. I have seen that you are in Burkina. Do you speak French? (because my english is bad). I am working at "KYOCERAMITA France".
          • pcs
            • May 2009
            • 26
            I have had other small units with this same issue and it was because of the one of the following.
            Is it going through a USB hub? If so try connecting it direct.
            Check to see if the USB port on the system it is connected to is USB 2.0 or higher if not try one that is 2.0.
            • kaborwen
              • Feb 2010
              • 146
              I Reinstall my computer and all is ok know.
              Thanks all.
              • kaborwen
                • Feb 2010
                • 146
                kaborwen@msn.com.
                Au plaisir de vous compter parmi mes amis.
                Bye!
                • Charles
                  • kaborwen
                    • Feb 2010
                    • 146
                    mail personnel
