kyocera 5035 code o630
  • digicor
    • Jul 2008
    • 1159
    I have a KM5035 that is throwing this code[0630] "only when the finisher is asked to staple to the left side of the page"???[did the 906 reset] I have reset the doc feeder and the finisher, the code is pcb board, but without the finisher attached it never shows, and the finisher can run but not evry function as i stated above,the code is also a grounding prob, I have replced the finisher to no avail, same prob, any suggestions besides changing the pcb board?
  • robscopyr
    • Mar 2009
    • 54
    DMA problem
    DMA transmission of compressed,
    decompressed, rotated, relocated or
    blanked-out image data does not
    complete within the specified period
    of time.
    Replace the main PCB and check for correct
    operation.
    • Jimbo1
      • Mar 2008
      • 845
      Ok....before you replace the board take out the transfer roller unit and check the contacts on it and where it locks in. We have had these contacts get out of shape and give this code. It's always under wierd conditions but that's what it can be.
      "Some days you get the bear, some days the bear gets you."
      Cdr. William Riker
