TaskAlfa 300i stuck on Welcome Screen
  • KEVIN900
    Copier Ninja
    • Oct 2009
    • 200
    my customer's TA 300i ( black & white ) is stuck on the welcome screen. I have a F000 code also. Please help.
    Kevin900
  • KEVIN900
    Copier Ninja
    • Oct 2009
    • 200
    F000 is system error. My dealership just started selling this brand a year ago, and now we're owned by Kyocera. So my experience level is very good, just very new with this brand. Thanks in advance fellow techs.
    Kevin900
    • JB1068
      Did you try upgrading the firmare?
      • JB1068
        I meant firmware.
        • KEVIN900
          Copier Ninja
          • Oct 2009
          • 200
          Last thing I did was new firmware.
          Kevin900
          • JB1068
            If this machine has a fax in it, make sure the fax option is in the right slot.
            • xeroid
              Document Technologies Pro
              • 148
              I would power down and remove the fax board and disconnect the ADF and see if it boots. Did the Firmware successfully complete or were there errors?
              • KEVIN900
                Copier Ninja
                • Oct 2009
                • 200
                No fax on this machine. And Firmware was done without a hitch.
                Kevin900
                • randula7
                  • 73
                  For stuck on the welcome screen Replace the main memory and check
                  F000 Operation panel PWB communication
                  error
                  1) Upgrade firmware, 2) Replace main firmware DIMM then upgrade firmware, 3) Replace main PWB, 4) Repl main operation panel PWB.
                  Replace memory
                    • 23010
                    I agree with randula. Chances are that the Code DIMM will solve your problem. Remember to upgrade the firmware immediately after changing the code DIMM. Otherwise you'll get a cf18A firmware error. =^..^=
                    • KEVIN900
                      Copier Ninja
                      • Oct 2009
                      • 200
                      Thanks Guys, I'll grab all I need from the showroom machine, but will start with the DIMM and a fresh flash. I'll bring the other boards too, but will take it one at a time and let you know. Look at ME ! 100 Posts ! EVERYONE just got a rep boost from me. Thanks again.
                      Kevin900
                      • KEVIN900
                        Copier Ninja
                        • Oct 2009
                        • 200
                        Follow up, Fellow Techs, it was the Main PWB. But I got a surprise call on my cell from some regional hack I never met, and he said the steps were taken in perfect sequence. Firmware, DIMM, Main PWB, Op Board. I was well armed, thanks to the showroom machine, thats now waiting for parts. You guys helped me shine today. Thank you very much. Whoop Whoop !
                        Kevin900
                        • dynsam
                          • Apr 2011
                          • 21
                          TaskAlfa 300i freezes on welcome
                          hi techs we have a TaskAlfa 300i recently purchased 2 week ago. when turned on it freezes on welcome screen with Memory indicator light on and Attention indicator light on and just stuck there. cannot go into service mode.
                          please need help asap
                          • jmaister
                            certified scrub
                            • Aug 2010
                            • 755
                            Find yourself a troubleshooting guide for the 250ci - 500ci series.
                            I've exactly the same problem you did.
                            swap the ram, upload firmware, WAIT for activity, it can take up to 30mins.
                            de ja vu?
                            Idling colour developers are not healthy developers.
                            • Masterchief
                              • Apr 2011
                              • 280
                              I agree with randula but my method is to go in reverse of his strategy...
                              I spent a whole day swapping PWB's and dimms from one MC to another, only to discover that it was the main operation pwb. I have had this happen 7 or 8 times so far and 3 of them was the op PWB, so working backwards save a whole lot of time
                              Also dont forget to try a different HDD
                              sigpic
