color calibration procedure
  • Dustin(WOP)
    • 223
    CAN ANYONE GIVE ME THE CALIBRATION PROCEDURE FOR A KM-C3225? WE ONLY HAVE ONE OF THESE OUT IN THE FIELD AND ARE NO LONGER A KEYOCERA DEALER. WE WERE ONLY A DEALER FOR ABOUT A YEAR AND THAT REALLY ISNT ENOUGH TIME TO LEARN ALL THE IN'S AND OUT'S OF THESE MACHINES. IF ANYONE COULD HELP ME OUT THAT WOULD BE GREAT. THANKS IN ADVANCE!!!
  • randula7
    • 73
    1 Press the System Menu/Counter key.
    2 Press [User Adjustment].
    3 Press [Color Calibrat.] ([ColourCalibrat.]) .
    4 Press [On]. Color calibration begins. Wait approximately 45 seconds.
    5 Press [Close] after color calibration is complete.
      • 23009
      There's a little more to it.
      1) In simulation U467 turn Off Auto Color Registration. Exit service mode. In simulation U467 turn On Auto Color Registration. Exit service mode.
      2) In System Menu, User Adjustment, Color Calibration, select On.
      3) In System Menu, User Adjustment, Color Registration, enter 4-digit admin code, load letter paper in tray #1, print calibration page, on the page at each group of lines select the line in color that most closely aligns with a black line, enter the number of that black line for each group, press complete when all the numbers are entered, reprint the calibration page to re-check the results (should all be at zero). Note: For aligning the yellow groups shine an ultraviolet flashlight across the yellow lines. Like magic, the yellow lines appear dark gray for easier identification. Ultravioltet flashlights are commonly found at firearm or hunting gear suppliers for tracking injured animals.
      4) In System Menu, User Adjustment, Half-Tone Adjustment, enter 4-digit admin code, follow the prompts.
      That's it. =^..^=
      • MrFred
        • Oct 2011
        • 27
        Re: color calibration procedure
        Thank you blackcat4866 for the UV light hint, I can never see the yellow well enough when doing colour registration.
