KM5035 Finisher Problem. PLZ Help!
  • RookieTech
    • Jun 2008
    • 46
    [Misc] KM5035 Finisher Problem. PLZ Help!
    When the staple feature is selected, the display reads "these functions cannot be combined." However, no other function or feature is selected. I would appreciate it if anyone can provide me with some help on this problem. Thank you.
  • aabarnes1
    • Mar 2009
    • 620
    turn collate off in machine defaults/ system settings
    Grant me the serenity to accept the things I cannot change.
    • RookieTech
      • Jun 2008
      • 46
      Performed as indicated with no success. Any other ideas?
        • 23006
        There's probably a finisher code (C8xxx) stored but not displayed. Perform a U906 partial reset to clear the code, and print a U000 error report to see what code that you are getting. =^..^=
        • blsquires
          • Nov 2008
          • 342
          the cannot be combined message may indicate that stapler has a problem .reset machine with a 906 as the machine may not be recognising the stapler
          • RookieTech
            • Jun 2008
            • 46
            Performed a U906 partial reset to clear the code. Hole punch and staple finisher now work fine. Thank you all for your help, it is sincerely appreciated!
