CS2114 Developer Change
  • mrfuser
    • 1626
    Does anyone remember the procedure for developer changes on the old CS-2114?
    Kelly
  • aragul
    • Dec 2007
    • 128
    CS-2114 looks like the DC-1470. If you have access to kmaconnect, they have a service manual for that machine.
    Sim 60 runs developer. To get into maintenance mode, hold down the Print key and Stop/Clear key and then turn on the main switch. Then press the Stop/Clear key.
    If you change the drum and cleaning blade, Sim 69 adds toner to cleaning blade (change 00 to 100 and press Print). Sim 73 clears the maintenance count (set every digit to 0).
    • mrfuser
      • 1626
      Okay, put new developer in. Looks good on mag roller until you run sim 60 in the machine, then mag roller is almost completely clean of developer. Very spotty at best. Any ideas why?
      Kelly
