Taskalfa 300ci Urgent case
  • Realtech
    • Oct 2009
    • 103
    This is an urgent case.
    One customer of us has a Taskalfa 300ci 220V use only letter size paper with the latest firmware. And today I installed a Fax system board on this machine. After I Installed the faxboard I turn the machine on to make sure the fax has been properly installed. The machine recognized the fax on board than I decided the update the firmware to the latest from the KMA.
    Ater that fax has been initialized than U600 has been execute country 253 europe has been insert the machine is although the machine is 220V.
    When sending faxes everything is ok the report shows the fax has been send successfully.
    I check all the paper setting default all of them is ok.
    At last I change the country to 181 US but same result when receiving faxes I got a warning on the display add letter paper in tray 1.
    Any Idea?
    • 23009
    There's a little more to this.
    Read exactly what is on the screen. Sometimes the messages are cryptic. "Load paper in tray #1" could mean that a specific media type has been set at tray #1 or tray #2, exempting that tray because the facsimile wants a different specific media type. There is also the "European" factor. What paper size are the fax receptions? Mixed? A4 is not the same size as letter, and will not substitute one for the other.
    I would suggest designating a paper tray as A4 paper size and "plain" media type, and keeping it loaded with A4. Also make sure that the facsimile can print onto "plain" media type. =^..^=
    • 10871087
      • Jan 2005
      • 1062
      I agree with Blackcat, look at your paper settings before you go down the firmware route.
      • Realtech
        • Oct 2009
        • 103
        Only when receiving faxes on the display appear load tray 1 letter paper.
        But sending faxes is ok always sucessfull.
        • correo.tony
          • 72
          In System Menu go to Common Settings -.- Original / Paper Setting -.- Cassette Setting -.- in Cassette 1 you must have configured Paper Size in Auto ( Metric ) and Media Type in Plain,
          with this your problem is solved,
          Bye !!
          • Realtech
            • Oct 2009
            • 103
            Our customer use only letter plain paper.
              • 23009
              I don't believe that you have answered any of my questions.
              Primarily, what size are the facsimile receptions coming in? =^..^=
              • PANG
                • 104
                ta250ci
                Today i come across with this problem, hope to share with u all ,latest Fware ,received size is auto on and the setting in system menu is the same as mention. when customer faxing over using A3 size ,TA250ci always print A3 size even there is A4 size in 1st cassette,(if A4 size fax over with 5 copy and happen 1 time A3 size got 1copy ,4copy is A4 size but its happen 1 time can ingnore) my issused is why using A3 sending fax received cannot go to 1 st cassette. Done sim600 .Thanks any input
                • taskalfaman
                  • Nov 2009
                  • 137
                  solution
                  Please, put the cassettes to auto size detection, not to a fixed size.
                  if you set the cassette to a fix size, it won't print, you need to put it on auto=> problem will be solved
                  • PANG
                    • 104
                    but its still A3 size paper selection even casette fixed to auto detection
                    • PANG
                      • 104
                      solution for this issuse reformed hdd ,solved.thanks
                      • Betong
                        • 16
                        pang
                        you have to play around with you paper settings and media type that's the only way to resolve it. i also encountered that problem and by changing the paper size and media type i solve it. read correo.tony and blackcat4866 thread what they are saying is correct. try different settings you will get it right.
