1128MFP color scan, colored lines
  • taskalfaman
    • Nov 2009
    • 137
    [Electrical] 1128MFP color scan, colored lines
    problem. 1128MFP, when scanning in color to pc. the customer gets sometimes lines using DP.
    -slit glass is clean.
    - settings with the test chart are done , SIM 425, 411.
    - changed settings in U068, tested all values also from -33 to +33.
    - changed ISU, ok for a while then problem reoccurred.
    Someone a good hint?
  • correo.tony
    • 72
    I replaced the engine board, in one of these models ( first production ) has experienced this problem and is solved by replacing the engine board!
    Bye !
    • taskalfaman
      • Nov 2009
      • 137
      hi,
      if you can show me the engine board .
      you mean the main pcb!
      sy
      • LNorris
        • Sep 2008
        • 645
        i just set one of these up and this happened. change the default color for the scanner to b&w. mine went away.
        • correo.tony
          • 72
          FS-1128MFP lines
          Look at the attached pdf !
          Bye !
