C 2000 and C 2550
  • luizalexdias
    • Jul 2025
    [Error Code] C 2000 and C 2550
    Kyocera Mita 7530 - After replacing a bushing of the motor assembly fuser, the machine showed these two codes.
  • Hutcheson
    • 15
    C 2000
    Image formation motor problem
    LOCK ALM signal remains high for 1
    s, 1 s after the image formation motor
    has turned on.
    Poor contact in
    the image formation
    motor connector
    terminals.
    Defective image
    formation motor
    rotation control
    circuit.
    Defective drive
    transmission system.
    Reinsert the connector. Also check for continuity
    within the connector cable. If none,
    remedy or replace the cable.
    Replace the image formation motor.
    Check if the rollers and gears rotate
    smoothly. If not, grease the bushings and
    gears. Check for broken gears and replace
    if any.
    C 2550
    Drive motor problem
    s, 1 s after the drive motor has turned
    on.
    Poor contact in
    the drive motor
    connector terminals.
    Defective drive
    motor rotation
    control circuit.
    Defective drive
    Replace the drive motor.
    if any.
