km 2530
  • tcypy1961
    • 773
    km 2530
    I'm using a polek test pattern which has two solid black squares on opposite sides and ends. when making copies 11x8.5 the square on the side closest to front side is solid and black however the square on side closest to the back side of copier has good solids on part and lighter solids that rotate. i've replaced the drum and transfer roller and the results are the same thinking about the m/c next. any thoughts???
    thanks!!!
    • 23010
    Personally I'd lean towards developing. See if the developing cylinder is clean & shiny, and there is a nice even brush of toner on it. =^..^=
    • n25an
      • Jul 2008
      • 1030
      yep I agree... definitely developer
      Sad To Say I Don't Have a Life
      I do this stuff on the weekends too
      • 10871087
        • Jan 2005
        • 1062
        You said the the quality issue was rotating, I assume you mean the the light streaks were in the lead to trail direction and not the the problem actually rotated on the page. If so, I concur with the other technicians, Try a new developing unit
        PS. Get an actual Kyocera (Miss Mita) test chart, the back of that thing is a nice even tone of gray that is perfect for working on this type of issue.
