Falcon 3 developer clumps
  • Jimbo1
    • Mar 2008
    • 845
    Has anyone else ever experienced developer clumping in little bunches on the outer edges of the mag roller on the Falcon 3 series(3050-4050-5050)? You can tell where it is by the spacing on the page which matches the circumference of the mag roller and it's always on one end.
    You get what looks kinda like hash marks at the top or bottom of the page.
    Got any idea why that happens? It's not a real big issue but I have a couple it happens on every two or three months. Same machines so there is a consistency somewhere.
    "Some days you get the bear, some days the bear gets you."
    Cdr. William Riker
  • bbv69
    • May 2010
    • 13
    Have not seen this on the F3's but did see something similar on the F2's. Check the air filters, we found that they were getting packed with dust and interfering with the air flow. This was causing a heat buildup in the machine that cooked the toner onto the mag roller.
      • 23006
      I've seen it too on a couple of my Falcon IIIs, but don't have any clear idea why. Dry-wiping the developer cylinder clears it up for a short time, but it returns. And it's always the same couple machines.
      Technically, this machine is monocomponent. So no developer, only toner. But monocomponent toners are more prone to this effect. In Canon terminology it's called "mottling". =^..^=
      • Jimbo1
        • Mar 2008
        • 845
        SAme here I just use a dry cloth and clear them up. You have to be persistent or it won't go away. That air filter deal sounds interesting especially since I didn't check them.
        Cdr. William Riker
        • vikingmita
          • Nov 2008
          • 163
          could this be as simple as the toner cart not being shaken before a change?
            • 23006
            Unlikely. The auger system would have broken up any clumps before getting into the developing unit. =^..^=
            • JR2ALTA
              • Feb 2010
              • 2033
              It was Katun's fault for me.
              Finally convinced my **cough** frugal boss to stop buying it for this model.
              • Jimbo1
                • Mar 2008
                • 845
                It's not Katun. We use OEM and it's standard in the service contract so all our customers know they get it from us.
                If not we set them straight.
                Cdr. William Riker
                • tech07
                  • Aug 2008
                  • 409
                  I agree about the air filters..I/ve seen some unreal clogged one's. If you don't replace them, at least remove and blow them out with air...there are several...6 or 7 i think
                  • vikingmita
                    • Nov 2008
                    • 163
                    was more thinking about mixing, not actual lumps & clumps getting past toner cart. i guess a more reasonable explaination would be heat/humidity
