hello i did not even to try update firmware pls help me how to update for this two machine?
how to update firmware in km-1820/2810?
1820 - Remove memory cover on right side of machine, one screw/pin. Remove plate inside, two screws. Insert CF card with files on root.
2810 - USB drive with files on root in the USB slot in front.
For both, power off, insert appropriate media, then turn on. Firmware will update automatically. Then wait until it says completed. -
Re: how to update firmware in km-1820/2810?
I have the same problem, where can I get the firmware file from? I tried looking online but no luck.Comment
Everytime I turn on the Printer, it displays Kyocera and thats it...it will just be like that for as long as it is on. I read somewhere here that you should upgrade the firmware using a SD card...so I got a card but can't find the firmware anywhere online.Comment
monstott2010
dont worry about firmware...its now a papwer weight... most likely the main board is shot which will cost more than the machine is worthComment
Had a couple of these it is either the main board or the memory. Try the memory stick firstComment
"The Serenity Prayer" . . .
God grant me the serenity to accept stupid people , the courage to not waste my time and energy on them , and the wisdom to know that I cannot fix STUPID .Comment
Sorry ..... KDA is the U S location .
I should have said " Go to your KM site ... ( for your location ) ... then you can log-in using the password you have as being a certified KM tech . " and download from there ."The Serenity Prayer" . . .
Thanks for the Help, but I am not a certified KM tech...wish I was so I can get the firmware..guess I have to think of another way.Comment
If the CS/KM-1820 cannot boot most likely the firmware is corrupt. You may possibly order the F-Dimm from KDA, Also the Flash IC on the main board could be corrupt. This would require a Main board repair. There are a couplr of repair centers that should be able to repair this board.Comment
I did install the firmware into the flash card and installed it on the board, turned it on and left it there for an hour and nothing happened. So am guessing I have to change a board or something. Does anyone know exactly which board I shall exchange and where I can buy it from?Do for one what you wished you could do for everyone. - Andy StanleyComment
oh, sorry I used a compact flash card not sd card. I bought the Firmware from "justmanauls", the guy selling service manuals on here.Comment
