is face-up printing possible?
  • bronco31
    • Aug 2009
    • 174
    [Misc] is face-up printing possible?
    I'd like to run the Kyo 620 as a printer (its almost all they do) and have it output face-up (no intermittent jamming as the machine inverts the print)....
    Of course the problem is the first print comes out, then the second on top of it.. etc
    is it possible to reorder the print job to print the last page first?
    man i hope the answer isnt Prescribe! im bit intimidated by it and supposedly theres really only one guy at Kyocera who is trained on it.. thx..
    Guy
  • DWise
    • 895
    I know that Adobe has the option to 'Reverse Order' before you print, not sure about other documents...
    Do for one what you wished you could do for everyone. - Andy Stanley
      • 23007
      I've looked for it, but not found it. I spent some time struggling with the C60, C62, C63 jams on the CS-8030. I did not find a way to avoid that paper path. But you may want to check the duplex switchback roller. On my CS-8030s it gets replaced as early as 155K, and occasionally lasts up to 500K. =^..^=
      • vikingmita
        • Nov 2008
        • 163
        it should have been an option somewhere to run simplex print straigt out. really annoying that it always has to go down to duplex unit. less wear, more stable. it's the same on 620-820, but hopefully the coming ones have a possibility to do that, but they prob just change to color touch screen and 'one network card for all', like the rest of the line
        • bronco31
          • Aug 2009
          • 174
          ok thx guys...
          Guy
          • aragul
            • Dec 2007
            • 128
            Try changing it in the printing preferences. Change the destination to face up and maybe check the Reverse checkbox that appears at the bottom.
            Sim U331 should change it for copies.
            • taskalfaman
              • Nov 2009
              • 137
              hi,
              maybe this is a solution?
              sim 331
              try it and please feedback!
