CS-620 Jam 10
  • Dave10
    • Jul 2008
    • 197
    CS-620 Jam 10
    Just had to post this as it is a really weird problem. We just put out a new CS-620 about 2 weeks ago. It has about 4000 copies on it. It is only used as a copier: no print, scan or fax. Went out there on a call yesterday for jam 10, ONLY when someone tries to "reserve next copy" when a job is running. You walk up when the machine is running and hit reserve next copy tab, put your originals in the feeder and hit start. The machine is defaulted to drawer 1. Just after the last original is ejected from the feeder, the machine will stop and show jam 10. If you clear the jam and hit continue, everything runs fine. If you default to another drawer, it runs fine. I reloaded firmware, and checked all settings against an identical machine down the hall. All settings are the same, and the other machine works fine on the same function. Anyone heard of this?
    • 22997
    This sounds like the sort of problem that would be fixed by firmware.
    The most current firmware is dated 5-14-10:
    Main (IPU): P2KPS010.7H0
    Engine: P2KPS011.1J1
    There is also new Cassette PWB firmware. If I'm reading this correctly, you need to replace the cassette PWB to update this firmware (old part #: 302KP94161; new part #: 302KP94162). It does not specifically list your problem, but fixes several other jam related problems, including J25 jams.
    Let me know how it goes. =^..^=
    • Dave10
      • Jul 2008
      • 197
      Replaced Engine board to fix the problem. Thanks for the reply.
