Kyocera km 4050
  • Barış KURT
    • Jul 2010
    • 72
    [Error Code] Kyocera km 4050
    hello ,
    I need to help about KYOCERA KM 4050 ERROR CODE "C 0060"
    was changed harddisk and
    uploaded firmware version "2GR_2000.027.018 2009.04.02"
    it have new firmware than mine ? or service bulletin about it.
    Black is Kyocera , Color is Gestetner.
    • 23009
    You've got firmware version 2.40. There are newer versions, most recently 2.44 (4-27-2010), but there weren't any "bad" firmware levels to avoid. Anything over version 2.06 should speed up the panel operation and be problem free. Have you run U024 to format the new HDD?
    C0060 does not necessarily point to a HDD. Is it possible that the wrong model main PWB or wrong main DIMM has been installed? I would check there first. =^..^=
    • Mohammad.anwar
      • Aug 2010
      • 11
      coo60 OFFFFFF
      I agree that this code is not Harddisk
      Code means the main board failure
      But through my experience just got me the same problem I've re-programming of the EPROOM itself
      Dont measure yourself what has been done untill now , but must be compared What You Can Achive with Your Ability
      • teconcopier
        • Mar 2013
        • 15
        Re: Kyocera km 4050
        Originally posted by Mohammad.anwar
        coo60 OFFFFFF
        which EPROM reprogrammiing
        i AM converting spped for km3050 to km5050 this is working good .i am using another 5050 machine spped ram pcb ,i dont know ram modal no please inform the modal name
        teconcopierservices@gmail.com
        click here
        • kkendric
          • 301
          Re: Kyocera km 4050
          C0060 = Main PWB type mismatch error.
          • darry1322
            • Oct 2010
            • 817
            Re: Kyocera km 4050
            The original post for the malfunction code is over 3 years old. The new guy has a question about speeding up a slower machine.
