Kyocera Mita Km-3530
  • tcypy1961
    • 773
    On a KM-3530 does image flow usually result in light or dark copies? And what would be the best way to darken copies on this copier? Any help appreciated, thank you.
  • Jimbo1
    • Mar 2008
    • 845
    Not sure what you mean by image flow. If the machine ahs been sitting a long time like in a warehouse you will maybe want to run drum refresh on it. Also sim 130 which is the toner sensor which makes sure it has enough. Is it just a density issue?
    "Some days you get the bear, some days the bear gets you."
    Cdr. William Riker
      • 22997
      Originally posted by tcypy1961
      On a KM-3530 does image flow usually result in light or dark copies?...
      If you're talking about developer density variation... the Falcon I is monocomponent. There won't be any variation because there is no developer, it's all toner.
      I'd take a close look at the primary charge wire if you're getting quality variations. =^..^=
      • Calcucatus
        • Mar 2010
        • 16
        Do you keep most of your equipment in a warehouse? Sell it instead. HA HA~!
        • copyaction
          • Oct 2007
          • 985
          empty out developer unit.
          clean mag roller with a green scrubby.
          refill developer unit.
          • Loud Grinding Noise
            • Aug 2010
            • 10
            what brand of toner are you using? oem kyocera or one of those generic katun ones. most kyocera toner cartridges have blue handles and usually those generic katuns have green handles.
            • Sayen's
              • 20
              Most light copies are due to bad transfer roller or broken bushing that hold T/C roller.
              • bilyahn
                • Dec 2006
                • 1470
                I have seen a lot of the T/C rollers with broken holders. Is this an issue or can you just leave them as is as long as they stay in the guides?
                • Sayen's
                  • 20
                  If the holder is broken the spring under holder will fall out, I would change holders.
                  • bilyahn
                    • Dec 2006
                    • 1470
                    That's what I figured as I remember with the Canons that had something similar the roller would always fly out causing all sorts of problems. Thanks for the response Sayen's
