CS-6030 with finisher problems
  • Dave10
    • Jul 2008
    • 197
    We have an interesting issue with 2 CS-6030's sitting side by side. Each has the big finisher attached. Twice within a few weeks, the customer called and could not offset sort in either machine. They can staple, just can't offset. If we go out and do a sim 906 reset, it works, but the finisher was not disabled and no C-codes are shown. Each machine is on a 20-amp dedicated circuit and the outlets check out fine. Anyone seen this before? Any ideas will be greatly appreciated. Thank you.
    • 22929
    Does this affect copying or printing or both?
    If it is just printing, I had a driver issue with version 4.2.1409. The customer was a title company, and when printing legal size with two hole punch, it didn't punch. This version of the driver also allowed selection of conflicting options, i.e. tray B and stapling. Version 4.4.0403, 5.0.xxxx, and 5.1.xxxx drivers have pop-up widows that identify and explain option conflicts. They both also allow two hole punches in legal prints.
    I don't know if this helps, but it's something to consider. =^..^=
    • Dave10
      • Jul 2008
      • 197
      It's both copy and print. I need to check firmware and driver versions, but the 906 reset seems to put doubts on the driver, unless something in the driver is partially disabling the finisher. Will check this stuff. Thank you.
        • 22929
        I tend to agree with you. I doubt that a driver could affect copy operations.
        Current firmware is 2-18-2010. That's P2FBS.0059K3 for main, and P2FB2911.S31 for engine.
        Did you look at U904 to see if any error conditions were stored but not displayed?
        It just occurs to me. Staple and offset are conflicting options. You can staple, or you can offset, but not together. There's no need to offset if the sets are stapled, yes? =^..^=
        • Dave10
          • Jul 2008
          • 197
          Correct on the functions question, but we weren't doing both at once. I just meant that other functions using the inner tray were working, so the finisher is not completely disabled, yet the 906 does fix the problem, at least for a while. Will try the firmware and post after it runs for awhile. Thanks.
          • Dave10
            • Jul 2008
            • 197
            Update. Did firmware. The problem has not returned. The firmware was actually up to date in the first place, but I reloaded it. Seems to have helped. Thanks for the replies.
            • jvingless
              Test the selanoid were the clincher assy is and also clean the sensors in the the stacker assy b/c if one stacker plate returns home but on the next sort it is not sensed it will disable itself
