Falcon III with fax sys (M)
    • 22997
    Has anyone noticed an increase in fax Rx problems on the Falcon III? Especially U01110 codes? This is happening on too many machines to assume that they have all developed bad phone lines all at once.
    Versions 2.42 and 2.43 were supposed to have a bug which caused lockups when receiving, and it was supposed to be fixed in version 2.44. The machines that I've looked at recently have all been at version 2.44.
    As an experiment, I've downgraded a couple of machines to version 2.40 to see if there's any improvement. =^..^=
  • taskalfaman
    • Nov 2009
    • 137
    Hi,
    I encountered the same fenomena, I downgraded the system.
    problem seems to be solved!!!
      • 22997
      What version of firmware are you going with, taskalfaman? =^..^=
      • tmaged
        Owner/Service Manager
        • Oct 2008
        • 1868
        Did you see the new FalcIII firmware with fax fixes ?
        Hope that helps !
        -Tony
        www.dtios.com
        Become a fan on Facebook
        • taskalfaman
          • Nov 2009
          • 137
          hi,
          When plugging in a Fax System M2, the machine was hanging completely.
          downgrade first and upgrade to the latest availbale version (2.44), now this machine is working properly.
            • 22997
            tmaged: If you're talking about version 2.44, that is the version I've had the most trouble with. As of yesterday (8/10/2010), I downgrade every Falcon III to version 2.40, until I hear about a better fix... =^..^=
              • 22997
              Originally posted by taskalfaman
              hi,
              Falcon III doesn't accept a fax sys (M)2. You must be talking about a Stratos (CS-2560/3060). And that firmware is at 2.45 (as of today). =^..^=
              • tmaged
                • Oct 2008
                • 1868
                Check KMA. Version 2.45a was released for fax & OP panel lockups.
                Hope that helps !
                -Tony
                www.dtios.com
                  • 22997
                  Woohoo!!
                  Any bets on whether it works any better than 2.41, 2.42, 2.43, 2.44 ... ? =^..^=
                  • tmaged
                    • Oct 2008
                    • 1868
                    My money is on NO, but stranger things have happened.
                    Hope that helps !
                    -Tony
                    www.dtios.com
                      • 22997
                      This morning I loaded 2.45a on our in-shop machine. So far 2.40 has been a vast improvement. No more complains from the office staff. =^..^=
