KM 5050
  • LNorris
    • Sep 2008
    • 645
    KM 5050
    I have a school with a Falcon III. when printing, copying or internal prints the first page is shifted off the lead side of the page. the rest of the pages come out correctly.
    we have swapped the middle feed assy and lasers. this is happening from all trays and bypass. i have gone thru the page alignment steps and i can get the lead to the right placement, then print again, it shifts.
    i brought it into the shop a month ago and it ran fine here for some reason. put it back and it went to do it again. i have put a 3050 in its place and it runs fine (thought maybe it was a power issue).
    i'm begining to grasp at straws now. anyone seen this or have any insight?
    thanks
  • kyoceradude
    The Great Gazoo
    • Aug 2006
    • 442
    Current firmware? Then reformat HDD. Sim 989.
    My mission here on Earth is to help all you Dum-Dums!
      • 23010
      Swapping in a 3050 does not necessarily rule out a power issue, but a power quality analyzer will. As we all know each individual machine responds uniquely to power issues. =^..^=
      • LNorris
        • Sep 2008
        • 645
        i was just thinking that the initial power up to create a copy might be a "surge" and cause it to misalign. then the issue goes to AC power supply (which is on the same circuit as a coffee pot) or the power components of the MFP itself. but if the coffee pot is affecting the 5050, i would THINK that the 3050 would be somewhat similar.
        i'm gonna try what Kyoceradude recommended and see if that has any affect, nothing to lose at this point.
        thanks guys!
        • tmaged
          Owner/Service Manager
          • Oct 2008
          • 1898
          I've seen this happen on Sharp machines & it's always the resist/registration clutch that needs replaced.
          Hope that helps !
          -Tony
          www.dtios.com
          Become a fan on Facebook
            • 23010
            There haven't been problems with the Falcon III registration clutch. The only (2) records from the database search for Falcon III and "clutch" are:
            squeak from FCL1-clean
            no lift MP Tray-lift clutch wrapped-replace =^..^=
