KM-520i Jam code 61
  • Jimbo1
    • Mar 2008
    • 845
    KM-520i Jam code 61
    We have a km-520i brand new at a customer location that has been giving jam code 61 Went out the other day and swapped the middle feed section with on from a Falcon III. Did so much better(one jam out of nealy 200 duplexed and stapled prints) that I left it in and we ordered a new unit that we could warranty.
    Another tech took it out and put it in and has been there all day dealing with the jam.
    Anybody seen it and any ideas?
    "Some days you get the bear, some days the bear gets you."
    Cdr. William Riker
  • Jimbo1
    • Mar 2008
    • 845
    Now we have run codes 21 and 24....taken the entire left door assy. and duplexer out there. Awaiting results. Still wondering if anyone else has seen this?
    Cdr. William Riker
    • flimmer
      • Jun 2008
      • 30
      Jam 61 is duplex conveying fault
      61
      Duplex paper conveying
      section 2
      The feed switch 1 (FSW1) does not turn on within specified
      time of the duplex paper conveying switch (DUPPCSW)
      turning on.
      1543 ms
      The feed switch 1 (FSW1) does not turn off within specified
      turning off.
        • 23010
        Sorry jimbo. I've not seen this. =^..^=
        • Jimbo1
          • Mar 2008
          • 845
          Well I am happy to report we found the problem. The lower clutch in the verticle transport was dirty. In a brand new machine. Looked like it had 300000 on it.
          Quality control. Wonderful stuff.
          Oh and the replacement unit is backordered. Surprised?
          Cdr. William Riker
          • jmaister
            certified scrub
            • Aug 2010
            • 755
            we've got a machine with this problem.
            Its a 420i, j61 intermittently. Visual inspection found nothing wrong. Hand tested the switch, I've gotta say I dont like'em. The logic state doesnt change immediately but with delay.
            not resolved atm.
            Idling colour developers are not healthy developers.
              • 23010
              The one I looked at was giving me J81 and J52 jams. The upper vertical clutch had one too many shims on the gear side. So did the duplex clutch.
              The gear side of the clutch should spin freely when not engaged, and both were a smidge too snug. Jamming supposedly happened only the first print of the day. I had a dozen consecutive jams before getting to the clutches. =^..^=
              • Venom
                Technical/IT Support
                • Nov 2009
                • 765
                We have remedied many J61 calls by using 2 springs instead of just one on the white idler rollers on vertical feed. Also use F3 paper switch spacers on the F4 vertical switches and lastly have had to replace vertical feed clutches on a few repeat offenders. Be sure to upgrade main firmware to Ver 7 and Options to Ver 1.12
                IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
                • jmaister
                  certified scrub
                  • Aug 2010
                  • 755
                  good stuff, thanks
                  • Jimbo1
                    • Mar 2008
                    • 845
                    I have come to the conclusion that Kyocera is Japanese for "backordered". Any questions.
                    Cdr. William Riker
                    • jmaister
                      certified scrub
                      • Aug 2010
                      • 755
                      Wasnt there suppose to be a permanent fix on the panels? The spacers was thought to be a temp solution.
                      bulletin: 8389/ 2GR-0040 (Rev. 1)
                      Do you have falcon4's that dont have this modified or updated panel? If its updated, were they still giving you j61/j21?
                      There's suddenly a surge of these jam codes, thought I dig a bit more here.
                      • Venom
                        • Nov 2009
                        • 765
                        I found that the spacers correct J22's, doubling vertical idler roller springs and vertical clutches correct J61's...should do it all while there!
                        • jmaister
                          certified scrub
                          • Aug 2010
                          • 755
                          one'd think that once a part is updated on the last generation machine, the updates carry over.
                          I've checked the manuals, the panels look the same lol. How can this kinda thing happen?
