how to use prescribe command?
  • aabarnes1
    • Mar 2009
    • 620
    Originally posted by Eric1968
    Even more better idea :
    Stop posting these annoying RTFM-postings. The guy is just asking for some help!
    Well said Eric !
    Grant me the serenity to accept the things I cannot change.
    • MFPTech
      • 486
      Re: how to use prescribe command?
      So what is the problem? Have you downloaded the utility? Have you composed the command? Have you written the command into a Notepad file? =^..^=
      I normally use the command prompt starting with Echo. If you create a notepad do you simply write the prescribe command or is there any specific syntax similar to creating batch files?
      Thanks in advance!
        • 23008
        Thanks in advance!
        Nope. The syntax of the PreScribe command stays exactly the same. =^..^=
        • MFPTech
          • 486
          #19
          You are vague there, but anyway, what I find easier than the jar utility, or print driver ways, is to simply type from the command prompt ftp x.x.x.x. (ip address of the machine) and then type only the prescribe command in a notepad, save the txt file and just drop it on the command prompt - voila!
