cs 3225c
  • tomcatt
    • Jul 2010
    • 92
    cs 3225c
    I am wondering a) does this machine have a reliable track record b) is this machine relatively easy to maintain c) what can I charge on a cost per copy basis to include parts,supplies and labor. One of my current non-profit customers has been offered this machine as a donation and are inquiring its usefulness.
  • aodtech
    • 194
    These are pretty solid machines. The earlier models had the Developer units collars crack, Fuser thermostat get worn down and cause a "Cappuccino Machine" noise and eventually code out and the Transfer Belt tearing. But unless the machine was sitting around for years, I find it hard to believe that those parts wouldn't have been replaced already. Is it a CS-C3225 or CS-C3225E. The E makes a minor difference really.
      • 23006
      They run pretty good. A few weakness are:
      1) The fuser unit thermistors rubbing an making that noise (There have been (6) revisions on that fuser-it should be resolved)
      2) The color developing units rarely make the full 300K, especially in low color volume settings. If you see a C, Y, M, or K speckled background all over the page, take a look at sim U131. If the reading is different than the reference by more than 25 points the developing unit need to be replaced. No separate developer-it's a unit, only. And to keep it interesting, I've seen a bad cyan developing unit cause magenta speckles.
      3) Do the color calibration every time that you see the machine. It only takes 1/2 hr and will save you lots of recalls.
      Sell them the service agreement. If you don't, it will be a battle every time you need to change a $300 part. =^..^=
      • just a tech
        • Jan 2007
        • 332
        I have to agree with blackcat. keep the colors calibrated, keep tabs on your DV units and you should be fine. Up-to-date firmware doesn't hurt either. All in all, I like them a lot. They've been out long enough now for most of the problems the machines experienced have been worked out by now. One of the problems I ran into a lot that hadn't been listed earlier by the other guys were the fuser exit ass'y gears deteriorating and turning into a white slightly gummy powder / dust that would fall into fuser unit area. After replacing the gears the initial time, didn't have problem anymore on those machines. Good Luck
