falcon 2 to falcon 3 upgrade problem
  • Loud Grinding Noise
    • Aug 2010
    • 10
    upgraded from falcon 2 to falcon 3....
    theres this CF card inserted in the falcon 2 to make us print these custom invoices. without the CD card, the invoices wont print the the way we like it.
    inserted the CD card in the new machine(falcon 3) and the invoices wont come out right on the pages.
    CF card has 7 folders in it...API, APL, CSH, Lang, PRE, TOOLS, WOK.
    the PRE folder is the only one with files in it...File Types: Files.
    pls help!!!!!
    • 23009
    Excellent observations. Was the first machine Off at the main power switch when you removed the CF card? Was the second machine Off when you inserted the CF card?
    The Falcon II is older technology. Falcon III is Wysecore technology. Though the machines are mechanically very similar, electronically they are very different. The older PreScribe commands will most likely not be recognizable by the newer machine. You'll probably have to have that macro re-written for the newer technology machine. =^..^=
      • 30303
      Is the new print driver configured the same way as the falcon 2?
        • Aug 2010
        • 10
        Macro re-written....how do i do that? i guess IC-Link, but maybe a little detailed help on how to do it?
          • Aug 2010
          • 10
          Configured in what way? all we did was installed the latest KX driver in the server room.
            • 30303
            Is the setting for Prologue/Epilogue the Same? Also is it set up to print from the same port IE 9100,9101,9102 etc Is pcl xl set as default?
              • 23009
              I would be delighted to help you out if I could write these macros myself. =^..^
                • Aug 2010
                • 10
                the driver is set to KPDL.
                cant i just use the macros on the compact flash card from the old machine? and yes both machines were power unplugged when the CF card was removed.
                also, does the CF card go in the blue cf port on the right side of the new machine or the cf port in the back of the machine on the main board after removing the rear cover?
