task alfa 300ci
  • Mohammad.anwar
    • Aug 2010
    • 11
    task alfa 300ci
    my friends
    i have task alfa 300 CI it has problem ....
    the problem is:
    when print or copy b/w or color there is no black color i already change "k" developer and transfer belt and trasfer roller and the lastthing i update frimware but still the same ....by the way i change the drum "k" but.... any idea please
    Dont measure yourself what has been done untill now , but must be compared What You Can Achive with Your Ability
    • 23008
    The code I would expect to see is C7101. I'd take a look at the developing unit agitation drive. There is a bulletin about defective developing and cleaning drive motors.
    You can test Fuse IP1 on the developing drive motor. The new style motor part number is 302H793091. =^..^=
    • Mohammad.anwar
      • Aug 2010
      • 11
      there is no code i'll check service bulletinthen i let you know
      thank you
      • aodtech
        • 194
        Remove the charge roller from the Black Drum unit and see what you get. If you get a black print, then I'd look at the Laser Unit. If still nothing, then it may be a bias issue. I'd trace that to a board or connection.
        • kyocera.team
          • Aug 2010
          • 126
          try to check the primary HV
          • Realtech
            • Oct 2009
            • 103
            I have the same issue Taskalfa 300ci error C7101 it's refer to the developer K sensor could someone fix this issue.
            Please let me know.
            • Realtech
              • Oct 2009
              • 103
              I have the same issue Taskalfa 300ci error C7101 it's refer to the developer K sensor could you fix this issue.
              Please let me know.
              • Frits
                • Jun 2009
                • 62
                sb
                here's the sb for the problem
