task alfa 400ci
  • blsquires
    • Nov 2008
    • 342
    [Misc] task alfa 400ci
    custmer switched to print black and white after colour runs out .they have now replaced colour .status sheet shows colours now full but the machine says .can only print in black and white .anyideas how to turn this off ,we have tried resetting print in black and white when colour runs out but it still wont print in colour.....is there a reset.
    thanks in advance brian
  • just a tech
    • Jan 2007
    • 332
    Are the cartridges OEM?
    • blsquires
      • Nov 2008
      • 342
      problem solved ,if you get it take out all colour toners close front door ,open put toners back in and close door again and it clears
        • 23008
        It went away, but did you fix anything? I don't know....
