We have a Copystar 420i that threw off a code of F357 while copying. Machine sat there for a few minutes then proceeded to show "Turn machine off/on" Any idea what this code stands for? We also have a few F278's that show in the log...anything?
Copystar (taskalfa) 420i --- F357 Error Code
The CF357 hasn't made my list yet, but the CF278 is Energy Saving Manager.
You might guess that a firmware upgrade is recommended. Sorry, that's all the details I have. Let me know what you discover. =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^= -
Figured out the 278's is thrown when you turn off the main switch without turning the little power switch off on the control panel first. Thats not a big deal but the other one is somewhat concerning...this machines having major duplex jamming issues with about 15k on the clock.Comment
Figured out the 278's is thrown when you turn off the main switch without turning the little power switch off on the control panel first. Thats not a big deal but the other one is somewhat concerning...this machines having major duplex jamming issues with about 15k on the clock.Attached FilesMy mission here on Earth is to help all you Dum-Dums!Comment
Does this also apply to the Falcon IV? That bulletin is for the TASKalfa.
Good to know. =^..^=If you'd like a serious answer to your request:
kitkitkit
Shubh Infotech Place For Web Solutions
SHUBH INFOTECH offers a wide range of Internet related services including web designing, fields. The list of clients includes Agricultural industries, Consumer products, Chemical and Pharmaceutical companies, Advertising and communication specialists, and educational institutions. Contact Us with our email Id : shubh24i@gmail.com, or visit: web hosting and maintenance. It has developed a lot of web sites for various clients from various :: Shubh Infotech :: Call us on: +91 992 663 9096 For more details : www.homejobs24x7.com
E-mail us at : infoservice_global@yahoo.in
Call us at +91-79-26826453
Mobile: +919377944133 or +919898583959
Website: http://www.online-home-jobs.comComment
Any failures in the firmware upgrade? =^..^=If you'd like a serious answer to your request:
no, not this time. had failures before on the 3000 sheet paper tray. called tech support and got wonderful advice - try the main pwb or the hard drives or the dimm. so i'm going cheapest route with the dimm first and see what happens.
all they told me about the codes is that they are engineering codes. duh, i knew that. just tell me what they are pointing to.Comment
Re: Copystar (taskalfa) 420i --- F357 Error Code
I'm fighting a CF278 code now.. Tech support was not helpful. It's as if they didn't want to tell me about CF 278 codes. Copies and faxes are fine. Print jobs are a problem..Did it once when I printed a status page. The copier will actually turn off and back on, then freeze up..Did hdd format and firmware. TA 300ci. Histoy showed 18 CF278 codes...For crying out loudComment
