Could someone help me to set up the Scanner functions for my Copystar CS-3035?
  • weipei
    • Jul 2025
    tks
    wei
    • 23006
    What sort of scanning did you have in mind?
    Your options are:
    Push scanning:
    scan to email: your doc becomes an attachment to an email
    scan to SMB: Your doc goes to a share folder on your PC
    scan to FTP: Your doc goes to a share folder on your PC
    Pull scanning:
    TWAIN: Brings your doc into another application like Publisher
    You will require a network connection to the scan card (and yes there are two separate network connections: scan & print).
    If I can make a suggestion scan to SMB is typically the easiest to set up. =^..^=
    • weipei
      tks for responding.
      i am trying to have it scanned to PC.
      wei
        • 23006
        1) Information Gathering-Collect the following information:
        a. Host Name of recipient PC: From the Start Menu > Run > cmd > OK > ipconfig/all > enter. At the top of the page note the Host Name (exact spelling/case sensitive, please).
        b. User Windows Login:
        c. User Windows Password:
        2) Create a folder to receive scans:
        a. Create a new folder on the root of the hard drive: C:\scans (any name is OK but name must be spelled exactly the same in all uses).
        b. Share the folder: Right-click the folder icon then drop to Sharing & Security & left-click > radio button Share This Folder > left-click Permissions > Everyone > checkmark Full Control > Apply > OK > Apply > OK.
        3) From your browser access the MFPs webpage:
        a. On the address line of the browser enter the IP address of the Scan Card, then
        Go.
        b. Select "Scan to SMB" Destination List > 001 > fill in folder owner’s name as you would like it to appear on the MFP display (“Joe’s Folder”) >
        > Host Name (see above 1a) > Login (see above 1b) > Password (see above 1c) > Path (see above 2a, Note: enter as ‘scans’ not ‘C:\scans’
        d. Click Submit at the bottom of the page. You’re done!
        4) Potential trouble areas:
        a. DHCP must be OFF on the MFP.
        b. An IP address can be substituted for the Host Name when the PC has a static IP.
        c. Windows login/password must be accurate. There must be a valid login & password. In situations where the login is causing a problem with connecting to the PC a new login/password can be created just to receive scans. That login does not need to be open at the time.
        d. Folder must be in the root directory. Sharing must be ON, with permissions at Full Control.
        e. Port 139 or port 445 (either can be used) must be open on the server.
          • 23006
          If you don't see "Scan to SMB" on the web page you may have to do two things:
          Upgrade the NS30 firmware above version 1.4.02 (currently is at 1.4.11).
          Scan to SMB may need to be turned On in Sim U512.
          • LNorris
            • Sep 2008
            • 645
            3035s need SFU dont they?
              • 23006
              With NIC firmware 1.4.11 SMB is available.
              • aragul
                • Dec 2007
                • 128
                I think SMB was added to only the 6030/8030 and Voyager (C3232 etc.). According to the firmware release notes, anyway.
                Which leaves Scan to SFU, so I'll paste in my huge list of steps for it: (for WinXP, meant for desktops with DHCP)
                1. The Scanner File Utility
                  1. Download the Scanner File Utility
                  2. Install the Scanner File Utility
                  3. Add the Scanner File Utility to the Windows Firewall
                  4. Configure the Scanner File Utility
                2. Pointing the copier to the computer
                3. Test
                • wyzeguy
                  SFU and instructions...
                  In case you're still having trouble I have the Scanner File Utility as well as a PDF with screenshots of most of the setup process in a self extracting zip file here:
                  • weipei
                    Tks a lot All.
                    I am making progress.
                    However, i am getting stuck at:
                    1) when I try to access the scanner website by browing the IP, I only see printer setup information. No scanner setup information at all.
                    2) I was able to register user information by going thru the display pad of the copier by setting up user name, password, IP.
                    3) When I try to use the any of following functions, I got "Unable to use scanner":
                    a) Scan to PC
                    b) Defaultsetting----scanner default setting---system basic
                    Continued Helps Pls.
                    wei pei
                      • 23006
                      Could it be that you have connected to the printer NIC card, but not the scanner NIC card? If it has both options there will be to RJ45 connections. =^..^=
                      • weipei
                        Yes, U R right blackcat. I did not connected to the Scanner NIC Card.
                        Now, All done.
                        So Many thanks to all of u helping me all along the way.
                        Wei Pei
