Fax not picking up.
  • kmtech
    • Sep 2008
    • 125
    [Misc] Fax not picking up.
    I have a KM 5035 with a Fax option when a call comes in it wont pick up, the dial tone is present and auto receive is on, also the ring number is set to 2, I hope I am missing something. Thanks in advance.
    Bill
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1858
    Did someone mess with the distinctive ring setting ? This would be the only other cause I can think of.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
    • kmtech
      • Sep 2008
      • 125
      I don't think so, but will check and thanks for the reply.
      • daveyball
        • May 2009
        • 314
        I have a similaor problem what is the distinctive ring setting?
        • tmaged
          • Oct 2008
          • 1858
          It's for having multiple calling lines on the same line. The phone will riiinnnnnggggg, the fax would ring ring. This has to be set up through the phone company. If the fax is set to look for a distinctive ring pattern, it won't answer a normal ring.
          Hope that helps !
          -Tony
          www.dtios.com
            • 22930
            Agreed. There's also the possibility that the phone line is out of specs. I've seen actual readings of: On Hook 40vdc & 72vac, Off Hook 12vdc, 0vac, Ringing 67vac steady. In this case it was a PBx box problem. I advised my customer to have PBx box serviced. Desired readings on a POTS: On Hook 52vdc & 90vac, Off Hook 12vdc, 0vac, Ringing 100-125vac alternating. =^..^=
            • kmtech
              • Sep 2008
              • 125
              Fix
              It turned out to be the small board with the speaker on it, I think NCIU board. So thanks for the suggestions and the 5035 an 2530 Nciu board is the same.
              Bill
