TASKalfa 180/220 Problem blank copy
  • rockista_viii
    please help me i replace a new toner in my copier but when i proceed in copying.the printout is blank or clear.please help me
  • techpro
    • Feb 2010
    • 22
    Did you install OEM (original) toner? Also if you haven't already I would try a simple power reset along with opening the left side door and make sure it is all the way closed. If the side door is open there will be no transfer.
    Good luck
    • rockista_viii
      yes this is a original toner and i try it to reset it several times.nothing happen.please help
        • 23008
        rockista,
        It's unlikely that the changing of a toner cartridge had anything to do with blank copies.
        More likely, while you were in the machine you did something to the transfer charge roller or it's contacts. The way to confirm this is to emergency-stop the machine while the paper is passing the drum (open a door while the paper is passing the drum). If the latent image on the drum is properly developed, you can be certain that it is a transfer problem. The transfer roller may have been removed from the machine, and the rear contact spring may have fallen out. =^..^=
        • rockista_viii
          hmm any suggestion because I change only the empty toner.
            • 23008
            rockista,
            ... The way to confirm this is to emergency-stop the machine while the paper is passing the drum (open a door while the paper is passing the drum). If the latent image on the drum is properly developed, you can be certain that it is a transfer problem. The transfer roller may have been removed from the machine, and the rear contact spring may have fallen out... =^..^=
            I think I just made a suggestion. =^..^=
            • rockista_viii
              ok thank you every one
              blackcat4866 thank you...
              • JustManuals
                • Jan 2006
                • 9838
                This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment from The Internet's largest collection of manuals
                Paul@justmanuals.com
                • Tebow83
                  • May 2009
                  • 92
                  would imagine it most likely transfer or dev unit.
                  • tedy
                    Re: TASKalfa 180/220 Problem blank copy
                    Hey there pls help me i have kyocera 220 photocopiar start to copy he gives blanck paper what is the problem?
                    • Where is my screwdriver
                      • Nov 2016
                      • 16
                      Does the developer roller have toner across it?
