this machine keeps jamming, only on color b&w runs fine, good 28 bond paper runs ok too. our normal 20lb runs fine in the other 250,300,400,500ci machines but will not run in this one, the eject switch is fine checked in U031, fuser is good has been replaced and tried good ones from another machine in the shop.... this machine is in a large client of ours and were beating our heads upside the wall to get this running. the firmware is up to date, the fuser seams to run overly hot compared to the other machines, cant hold you hand to the plastic at all. any ideas would be greatly appreciated. thanks
