CS-C3232E Color Shift
  • Ingersoll
    • Nov 2008
    • 74
    [CQ] CS-C3232E Color Shift
    Has anyone seen a 2 inch color shift to the right (towards trailing edge) on a Kyocera color copier? Magentia is offset from proper position.
  • ebm
    • Apr 2007
    • 183
    Color registration adjustment doesn't help? TB 2 addresses the color registration adjustment for this model. However, 2 inches is quite a shift. Is it possible to post a pdf sample of the problem?
    • Ingersoll
      • Nov 2008
      • 74
      Here is a sample, the defect moves around left - right, but is the same:
      • ebm
        • Apr 2007
        • 183
        I would try replacing the magenta drum/image unit based on the sample.
          • 23008
          You'll be very lucky if the drum helps. I'm thinking that only a laser unit could produce this problem.
          Have you tried re-loading the firmware? =^..^=
          • ebm
            • Apr 2007
            • 183
            [ATTACH=CONFIG]6757[/ATTACH]
            Is this a color copy/print or black? What happens if you run mono color copies -cyan,magenta,yellow,black?
            • aabarnes1
              • Mar 2009
              • 620
              I agree, had this or very similar on a utax 1625 (kmc2525) had to replace laser.
              Grant me the serenity to accept the things I cannot change.
